Alright guys bear with me on this because I'm thinking way outside of my knowledge base and I'm finding it hard to articulate my question.
Say you have a humbucker with wind (X), has a A2 magnet, and reads 7.7k.
1. Only changing the magnet (A3, A4, A5) what is the effect on the tone? Does changing the magnet also change the DC resistance if so in what way up/down?
2. How about keeping the A2 and increasing/decreasing the DC resistance say up 8.0 or down 7.4 etc?
3. Using degaussed magnet does what exactly?
4. In general what does the DC resistance indicate? (i.e. does high resistance=compressed and easier to overdrive amp and low resistance=clear clean sound)
I have done a search and read quite a bit on the properties of the magnets but not so much on how changing the magnet affects the tone as opposed to the properties of different magnets.
Below is some of the "info" I have found online:
A2 is middy with softer/ squishier lows and less top end
A3 will give you a bit more top end with a bit of A2's squish
A4 more top and low end and is sometimes referred to as "stiff"
A5 has yet more top and low end
Also
A2 vintage sound
A5 modern, scooped, emphasis on highs and lows
Degaussed magnets=lower output
I understand that within a pickup there a lot a variables that influence the sound. I'm trying to understand in simple terms the variables I listed in the example described above. Mainly looking for answers to questions 1&2 as the others look like they may not have a simple answer. Like I said not really my lane.
Also
A2 vintage sound
