Rocco Crocco
- Joined
- Feb 7, 2013
- Messages
- 9,902
- Reaction score
- 19,017
your saying you think the necks on the epi trad pro's are fat feeling ?
Yes most definately. How does your feel?
Looks like if you want a Trad Pro, you'd better get one this weekend. Here's the Guitar Center Black Friday ad - I don't see anything worth buying on there ...
https://blackfriday.com/stores/guitar-center/ads/black-friday
Uggg. Not a PU height issue. Could be a bad pot or a faulty connection. You could try turning the bridge volume knob a dozen time to maybe knock of any oxidation that may have built up, and try jiggling the wires in the control cavity while the guitar is plugged into the amp see if you can locate the exact source of the issue.
If that doesn't work and you really like the guitar otherwise, you may consider finding a Epiphone/Gibson repair center close by. They will fix it at no cost under warranty. This is a better option than return/replace because you may get unlucky again and get a guitar with other issues.
Good Luck.
