Moodivarius
- Joined
- Feb 26, 2022
- Messages
- 148
- Reaction score
- 285
I looked all of that over before deciding what to do with our build.Interesting option for the neck joint. Usually the singlecut specials/Jr's have the cutaway shelf and the full size tenon as a way to avoid potentially problematic narrow wedges under the fretboard that taper to nothing.
The Epi’s & Gibson TV Yellow, looked like a full sized tenon, but the Gibson LP Special Tribute looked more like the body in the cut-away, ran out to the neck joint, like a regular LP.
The TV yellow have the body step out at the cut-away, to cover the edge of the full width neck tenon. Another obstruction, when trying to work the higher registry, we didn’t like.
Tribute
Here you can see on the TV Yellow, the fingerboard rises, as it gets to the end by the neck pickup, to get the proper neck angle.
Now looking at things on the Tribute, maybe Gibson angled the front part of the body to follow the taper of the mortise to create fingerboard flat with the face of the body?
If not, zero neck angel, and the action will always be high.
I will have to add little wedges under our fingerboard to fill the void between fingerboard & body. Thought of that before we started. Just assumed Gibson did that on the Tribute. But maybe they did something different.
Scott
