Weaseldust
- Joined
- Mar 5, 2022
- Messages
- 97
- Reaction score
- 135
about a month ago the red diode light suddenly became very weak...days later didnt light up at all, but pedal worked..and then next time i tried a day later or something, nothing, just dead.
i took it apart and began troubleshooting the only way know...with a multimeter to trace the signal and see where it stops. I took far too long time before a saw the disasterzone ... a Diode right next to incoming current had made a brown mess ... This is what that diode is for, protecting against wrong polariity current...i found out later when i looked up the shcematic, something i should have done first thing
but there is no chance i could have done it...i only have one powercable that fits, it is a 3,5mm inputjack for power.
the only thing i can think of is over a year ago when i didnt have a powercable to a a little epiphone slash amp...they run with 24volts adaptercable, and i have an adapter you change values on and different tips for input, only the could i have done something like that...why would i all of a sudden try to hook THAT up to my Rat ???
Does anyone have any ideas ?? what could have happenend here ? ... And why did it die gradually over a few days ?? i thought something like that happend with a sudden.
If I did something last year, fed it 24v could that have damaged something else that since then just been a ticking timebomb??
any other helping tips...im unsure about how you troubleshoot a pot for example...or the op-amp chip LM308N if that is dead that´s no good...i always heard about that being something special..
So do have any pedal and electronics wizards here ?? Help please and thank you
