Les Paul Gold Top Gold, plus SG Cherry trans red...
KelvinS1965
I bought a tin of nitro 'Les Paul Gold Top Gold' a while back as I had a plan to refinish my 60s Tribute Gold Top with a gloss finish. In the end I changed my mind as the satin finish is starting to wear nicely and I like the look/feel. It sat in my cupboard for a year or more...fast forward to a refinish on a Fender Jaguar that came in 3 tone sunburst poly. I decided to use the Gold top gold under a transparent red (actually intended for SG Cherry finish) to create a sort of Candy Apple red.
I think it's turned out OK and seems to have that 'iridescent' effect under bright light, that should come out more once I do the final buffing when the nitro has fully hardened.
This was how it started:
Jaguar in 'Gold Top gold'
2 coats of 'SG Cherry' red transparent nitro:
Did a little bit of buffing on the edges tonight, after 3-4 coats of clear on the previous finish:
I guess that a lot of 60s guitars were finished with car colours, but it amused me that I got a 'classic' Fender colour by using Gibson colours. :)
KelvinS1965
Had chance to give the back and front a buff, will probably give it another buff after I've left it to harden a bit more, then I'll re-assemble it.
This is a 'Parchment' pickguard that I put on after I made some changes a while back when I converted it from SH config to SS.
This was how it looked back when I bought it last September; it's a bit different now. :)
KelvinS1965
I used some fine micromesh to wet sand the front today, then another buff to get a really glassy finish. Hard to photograph though, but it's absolutely gleaming now. I painted the cavities with conductive paint and re-fitted the trem/bridge plate and strap buttons. I've got it hanging from the strap in the garage now during the current hot UK weather just to let it harden off a bit more before I re-assemble it later this week. :)
After the micromesh and buffing, nice reflections on the top right of the picture:
After the conductive paint and refitted the trem/bridge:
TheZ
Wow that looks awesome! How did you strip the original finish? I'm getting ready to go mano a mano with a pretty thick poly finish myself.
KelvinS1965
I used a heat gun and a metal scraper to remove the poly finish. Hence some of the scorch marks on the bare body on the very top picture. Took me about an hour, then a bit more for sanding it smooth.
KelvinS1965
Did a second coat of conductive paint and a little buff, left it hanging up in the garage for another few days to harden more so I can re-assemble it on Wednesday night hopefully, ready for band rehearsals on Friday night.
