Kingsley Pedals FS (2020 - Page V2, Constable V2 & Jester)
RAG7890
Selling 3 x brand new Kingsley Pedals.
All are current production with the latest upgrades received earlier this year from Kingsley after a long build / wait time.
All as new condition, only plugged in & tested.
All come with a US Power Supply.
Pics below are ex the Website but can take actual pics if required............they look like the ones below;.
Kingsley Page Boost: -
"The Kingsley Page is a hand-wired tube boost pedal featuring a 12ax7 tube running at high voltage. Suitable for use as a clean or slightly driven boost, the Page also excels at pushing an amp or pedal into overdrive. In addition it produces excellent overdrive and distortion itself when pushed with another boost pedal. The 9VDC power supply (provided) is converted to both 6.3VDC for the tube heaters and 250VDC for the tube plates."
Kingsley Constable V2 Preamp Pedal: -
"The Kingsley Constable is a tube guitar preamplifier modeled after the classic "plexi" design of the late 1960's. It is designed to push a power amplifier directly but may also be used into the effects return of a guitar amplifier effects loop. While the most authentic plexi tones are achieved by using one of the above methods, the Constable also features a mode of operation that attenuates its output to allow it to be run into the front end of a guitar amplifier or in front of other guitar effects pedals, for a clean boost or mild to medium drive pedal.
The Kingsley Constable uses two 12ax7 tubes running at high voltage (around 270VDC) to get the most authentic valve tone out of its hand wired circuit.The Constable has been up-dated and V2 is now shipping. While all the V1 sounds are still available, V2 has a more versatile feature set, including switchable Master Volumes and an additional treble reponse mode.
The Constable has been up-dated and V2 is now shipping. While all the V1 sounds are still available, V2 has a more versatile feature set, including switchable Master Volumes and an additional treble response mode."
Kingsley Jester Overdrive Boost Pedal: -
"The Kingsley Jester is a hand-wired tube overdrive and boost pedal that uses two 12ax7 tubes running at high voltage. The circuit is hand wired and features hard-wire by-pass on/off footswitches. The overdrive circuit is designed to capture the essence of the Kingsley Deluxe series overdrive tone in a footpedal format. The circuit is based on the overdrive channels of the Deluxe 32 and ToneBaron amplifiers, with the necessary adjustments made to allow the circuit to drive the front end of other amps."
Pricing: -
Kingsley Page Boost Pedal = USD375 (price includes shipping)
Kingsley Constable Preamp Pedal = USD495 (price includes shipping)
Kingsley Jester Overdrive Boost Pedal = USD495 (price includes shipping)
Allow 2 - 3 x days to pack & send the parcel. Each unit will be securely packed in Bubble Wrap & then sent in a heavy duty padded Post Bag.
PayPal is fine but buyer covers the fees. Local US wire transfer is also fine; i.e. you can pay a local US Bank Account if you prefer.
Thanks for looking.
:cheers2:
