Texas07R8
- Joined
- Jul 15, 2008
- Messages
- 2,425
- Reaction score
- 102
I decided to pull the trigger and get an attenuator for my Marshall Vintage Modern 50w Combo.
I checked out as many as I could and kept coming back to the Weber MASS units. They seem to be fairly priced and well thought out. Plus they offer some features others don't or not as nice.
The unit I got was the MASS 100w. It uses a speaker motor (without the speaker cone attached) as a real time load plus your usual resistors, etc. that other attenuators use.
This attenuator has a low-mid volume and a separate mid-high volume that controls the sound level to the speakers plus a bypass and a range switch.
Instead of having one rheostat that attenuates everything, this one has two so you can variably add in any treble loss you may get because of attenuation. Zero both knobs and there is no sound to the speakers but the line out is still functional so you can do silent recording if need be. My VM amp doesn't have a line/DI out so this may be something to play with. The main reason is to use light attenuation to get a little more gain and moderate sound levels. It was $160.00 which isn't too bad for an attenuator. My amp is 50w but they caution about using a hotter attenuator so you're not maxing it out when you dime your tube amp and suddenly it's really putting out close to 70w or higher depending the model of tube amp.
I hope it's what I need, I don't want to dime my master volume, I just play in my home studio and I want to get my MV up around 6-7 but the actual output volume level is around my current level which is around 3 on the MV and my preamp about gain on about 7-8 on the low gain setting.
I hope to have it by the weekend.
