Issue on my Laney IRT Studio !!
Mockbel
Hello
I am back to use the preamp section of my Laney IRT Studio after may be a couple of years of using it as a power amp only (plug the pedalboard to the Return of the FX Loop)..
For those who are not familiar with this amp, it has 3 channels: Clean, Rhythm, and Lead
Clean and Rhythm channels are working perfectly but the Lead channel has a very low volume.. I need to turn it to max just to match level 3 of the Rhythm channel volume which is definitely abnormal… Lead channel should actually have more gain than Rhythm channel.
I tried both 1W and 15W inputs… I gave the gain and volume pots some cleaning spray but zero effect on the issue.
What can be the root cause of it if anyone can help ??
CB91710
Not Michael Sankar
Swap in a spare tube for V1... or swap V1 and V2 and see if the problem moves to all channels.
Tube could have gone bad over the years.
Mockbel
I have already replaced a tube last year.. but symptoms were different.. volume was keeping going up and down and replacing a tube resolved it.. I will give it a try anyway.. so I have more than 15 screws to unscrew now.. damn for that so bad case design !
cybermgk
My suggestion as well. With 3 preamp tubes, I'd bet the Lead stage uses a half of a tube, the others don't, and it's failing, or just bad. If I were to guess it would be V3. But, that is a pure guess. Best option, is to take a known good tube and try it in each spot..
