Gibsonrocknroll
- Joined
- Jul 10, 2010
- Messages
- 3,369
- Reaction score
- 2,406
I didn't care for the burstbuckers. I like the classic 57/57 plus combo.
Yeah, the Throbaks I recently purchased for my Standard are still sitting on the shelf. I pulled out the Standard to make a decision about replacing the pickups or just leave well enough alone. I think I’ll just leave well enough alone! I’m an old engineer and I truely believe, if it ain’t broke, don’t fix it. I’m sure I’ll find a home for the Throbaks. Rock on Sir!@mjross I completely agree. I used to have an '07 SG Reissue that had burstbuckers and was one of the worst guitars I've ever owned. The sound was thin, and chords never had a full 'together' sound - always sounded disjointed. What made it worse was that guitar was trying to replace a guitar that I mistakenly sold in a fit of ignorance - a glorious 2005/2006 Gibson SG Guitar Center exclusive '62 Reissue, which was one of the best guitar tones I've EVER gotten.
With my 2021 LP Std 50s, I knew it came with BBs and I wanted to hate them. But I don't. They took me completely by surprise. I had an obvious bias against them and that bias was crushed. I was going to put in an original set of PAFs that I have, but haven't felt the need to since I don't think they'd improve the guitar by much. I still might just for kicks, but it would really be out of curiosity, as the sound is completely satisfactory.
My goldtop of the same year also sounds far better than my 04 Std - specifically in the neck. The bridge isn’t as noticeable but the neck difference is massive. On my 04, unless I’m specifically looking for slash tone, my neck is a little too muddy to do anything else with. If I’m looking for a thicker sound, I usually go middle position with the neck volume rolled back to 7-8 and the bridge volume at 10. My ‘20 goldtop though, I can run on the neck position full volume and actually roll the tone knob back and still love the sound. Very thick but articulate and not muddy. Granted I am comparing ‘04 Burstbucker V’s to my goldtop which has 1 and 2’s and that may not be very fair but I will say, I’ve read forums for years about how much people hate burstbucker V’s and have yet to see many forums about hatred for modern BB’sI’m going through rotation and pulled out my 2020 Standard Gold Top. I’m not sure what’s going on but these damn Burstbuckers sure sound killer. Overall the guitar is amazing but I just do not remember Burstbuckers sounding this good. Maybe I just got a good set or something. Bought a set of Throback 101’s but I‘m struggling thinking about changing out the Burstbuckers. What are you guys experiencing?
I found this thread and post interesting. I do have a question for everyone about pickup height. I have 4 Les Pauls all with BB. Two are weight relieved and two are traditional. All are High Performance. I find that the traditional have more grit in the sound which I like, and the weight relieved, one is brighter than the other and both are brighter than the traditional. Could this be a result of pickup height? And is there a sweet spot distance from the strings? Would you measure this while fretting a particular fret, say the 14th? Just curious to know what you all think about what is right and the technique used to determine it. ThanksI've found the '61s to be unusually sensitive to height. I've had them in two different guitars and each time they have taken quite a bit of tinkering to get right, but once you get them dialed they are some of the best pickups I've ever used.
Really wish I could help but I know very little about pickup height adjustment. I pretty much depend on my tech to adjust the height properly. Every one of my guitars go to him shortly after I receive them! Hopefully someone will chime in with a answer to your question!I found this thread and post interesting. I do have a question for everyone about pickup height. I have 4 Les Pauls all with BB. Two are weight relieved and two are traditional. All are High Performance. I find that the traditional have more grit in the sound which I like, and the weight relieved, one is brighter than the other and both are brighter than the traditional. Could this be a result of pickup height? And is there a sweet spot distance from the strings? Would you measure this while fretting a particular fret, say the 14th? Just curious to know what you all think about what is right and the technique used to determine it. Thanks
It could be down to weight relief, rather than pickup heights. My Trad's BB 1 & 2 are +- 4/64” between string and pole on the high e-string side when pressing the string at the highest fret. Just in the process of tweaking the heights, I've found that a 1/32” difference either way can make or break the tone. On the low e-string side, I lower (or raise) the pup height so that the two e strings more of less are the same volume. You might prefer a touch louder low e-string or not. This will take a bit of close listening to get it the way you prefer. Then I make sure the other strings are not noticeably louder of softer sounding compared to the two e strings.I found this thread and post interesting. I do have a question for everyone about pickup height. I have 4 Les Pauls all with BB. Two are weight relieved and two are traditional. All are High Performance. I find that the traditional have more grit in the sound which I like, and the weight relieved, one is brighter than the other and both are brighter than the traditional. Could this be a result of pickup height? And is there a sweet spot distance from the strings? Would you measure this while fretting a particular fret, say the 14th? Just curious to know what you all think about what is right and the technique used to determine it. Thanks
Forum members hate people like you lolI noticed the more I practice, the better guitars sound.
