tonepad
- Joined
- Nov 12, 2013
- Messages
- 145
- Reaction score
- 59
Finally weighing in on this...First welcome to the OP and it's a decent topic to discuss, in fact I was just getting ready to start a thread when this popped onto the radar. Here's what I've been experiencing.
I have 3 LP standards....#1: 2006 G0....#2: 2005 LP Faded....#3: 2008 LP Faded (chambered) After successfully finding bridge pups that I liked for these 3 (another topic) I decided to take on the neck pups in an attempt to make the pieces more usable in that position. The '05 Faded responds very well to having a Duncan '59 in the neck, in fact it's a great combo. The '08 LP Faded being chambered is a bit less fussy (they are a bit thinner sounding what with less wood and the chamber effect) so The stock BB Pro was not bad and the SD '59 is also stellar and for now I'm running with a Seth Lover minus the cover. The bitch of the bunch is the G0, which while about the same weight as the '05 Faded doesn't like much of any Neck pup I've tried. I'm specifically talking about the low E and A strings when playing an F/C/G/A down there. I've put a '59 in that piece for now but it def sounds muddier in there than in my other 2, but the best yet of my available selection. So I'm coming to the conclusion that the wood in the G0 is creating some of the mud. It's not just about weight since the G0 is slightly less than the '05 Faded. (8.09 lbs vs 9.06 lbs) so that's a head scratcher.
My test amp is a '65 Fender Deluxe with either the stock Oxford (now pulled for) a New Jensen C12Q and soon a vintage Jensen Concert recone. Now this amp/speaker combo has a rep for being low end challenged, but since 2 of the guitars are sounding good I'm staying with that amp.
Hope my findings shed some light. My take away is that it's not a universal problem so that may explain why many posts are from users w/o issues, but many of us with even multiple axes can experience the issue and though there are solutions not every fix works. I've tried the cap in line trick and I'm going to put one on the SD '59 in the G0 to see if it takes me the rest of the way.
Thanks to everyone for the input here, I've gotten a lot of info. Maybe we should finally get a sticky going on this common problem.
