NINFNM
- Joined
- Dec 24, 2014
- Messages
- 269
- Reaction score
- 433
I have always thought that the Nashville system was superior from an engineering point of view compared to the ABR. Some will thought that it's ugly or that it doesn't transfer as good the vibrations.
I disagree with the first point, and second, partially, the other one.
The Nashville system has more treaded contact than the ABR. Their Studs/Bushing connection has more threads than the Wheel/Post of the ABR.
They also has a cleaner and better height adjustment, in the same line as the tailpiece was designed.
Not to mention the non rattling and more stable saddle system.
For me the weaker point was the wood contact, so I thought that the best of both worlds would be a Nashville system, but with the bottom part of the bushings resting directly onto the wood, so, I went for it.
First I got a couple of maple plugs with the same diameter as the bushing holes:
After measuring the holes I cut them to a length such that the bushing made direct contact at their base with the maple (a hair longer in fact to ensure that):
After hide glueing them and let them dry overnight, y put the bushings back in place.
I had to hammer them HARD, Not only it's a super tight fit, but the bushings are a bit nailed onto the new maple plugs:
The finished job:
My idea was to compare the mod with the same ol strings, but unfortunately I broke two while restringing, and then I had to replace them all, so the comparison is not fair.
Obviously now it sound much better, and also louder, but the fresh strings are the main responsable for that.
What I can notice is the neck vibrating more in my hand, but maybe is placebo.
Honestly I don't care about sustain, but if I place my hand behind the headstock, it keeps ringing and ringing long after strumming a chord.
I will play it these days and let it sit so I can have a better perspective.
At least the goblins in my head have shut their mouths.
The finished job:
