If you had to pick only one position ....
Which would it be?
  • Neck
  • Middle
  • Bridge
  • Hey buddy...that's kinda personal
Results are only viewable after voting.
Musha Ring
I have five Juniors. The decision is usually nondescript. That said, I do enjoy some neck-pup action occasionally.
-Plus, I like the word "nondescript".
Do you find rolling off the tone scratches the itch when you want a neck pickup sound?
As per the poll, I choose middle. All day, every day.
Bobby Mahogany
I learned to use the neck later in my playing life
so I guess that on usage I should choose bridge.
gball
If it was only one it would have to be middle for sure. I already spend most of my time that way anyhow.
MiniB
In the middle position, especially with 50's wiring, you can blend in more or less of each pickup to get much of what you would with either alone, with some interesting character added. For example, my favorite 'lead' setting is with bridge pickup volume up and neck rolled back, for a 'fat lead'. So for me, middle.
endial
Not really. Just a more bassy-mid-rangey tone. You can really get some meat out of a p-90 on 9 vol and the tone on 4. Big, bloody, thick steaky meat. Frickin' juicy and delicious, dripping with fatness. Yep.
palmerfralick
exactly with 50's wiring you don't really need a pickup selector as you can do the same thing by adjusting volume levels.
Musha Ring
This is true.
I took your advice by the way and dropped a 250k tone pot in the used Junior I picked up a few weeks back. I'm much happier with that than the 500k I had in it. Thanks for the advice!
MiniB
I've had guitars with 60's wiring where it really is like independent volumes, whereas with 50's the whole thing will 'shut off' if just one of the volumes is turned all the way down. But...the blended tones aren't as interesting or as easy to get to with less turning like it is with 50's wiring.
LP1865
My playing style almost always needs the bridge pickup
GT40
Bridge. I'm probably there 80% of the time anyway.
You can use the tone control to roll off treble to make the bridge warmer/muddier if it's all you have. You can't add in treble to the neck that is simply not there when the tone is already maxed.
For me, middle position is useless. I'd prefer a two position switch so there isn't a chance of landing there by accident.
