If I'm not mistaken it has a asymmetrical neck, or is that only for 2008 Standards?
And for gosh sakes, take off your freaken serial number.
Look at the neck from the side. If it looks skinny, it's a 60's. If it looks thick, it's a 50's.
If it's a faded I would say it's a 50's neck like the ones they use on the Studios.
I would go play a bunch of Les Pauls in some stores, knowing what necks you're playing. You will pick up on the differences. I like both and don't have trouble playing on a 50's or 60's neck. The really thick baseball bat 50's on some of the historics turns me off though, but those are pretty much only on some of the historics. You will know that one when you play it.
My 2004 was documented as having a 50's neck but feels like a 60's neck. With that being said the 50's and 60's neck profiles can be quite misleading. 50's necks are known to fill your hand but some don't even come close to delivering.
I have had the same expierence...My 2004 feels way to thin to be a 50's neck, and a bit thicker than a 60's...almost in between.
When I got it back in 04 it was sold as a "50's" neck.
Pull the bridge pickup and take a look in the cavity..
LP5 = 50's neck
LP6 = 60's neck
or e-mail Gibson with the serial no. and they'll tell you.
Cheers!
Comedy, you guys are paranoid. They could simply make any number up they want that corresponds with Gibson's format, why would they need his specifically, and what would it matter? LOL+1. Remove the serial number from your original post. Companies that counterfeit Gibsons use the serial numbers on their fakes.
Or if you have the Gibson Production Checklist it will tell you either way (I forgot about this).![]()
I'm not sure on this, but I think I read that the Production '50s and '60s neck have different truss rod acorn nuts. Gold for one and silver for the other, to make it easier to identify during neck/body assembly.
If some of you guys can show your nuts, that would be helpful.![]()
