I have modified my Gibson 335 removing the Stop Bar to put a Trapece Tailpiece
cefobe
I hadn't used my Gibson ES-335 for a long time and that must be because some things about it bored me. One day I started researching on the Internet about the sound differences that could exist between a 335 with Stop bar and a 335 with Tailpiece. The truth is that I did not find much information, but what convinced me the most was they said that guitars with Tailpiece have much less strings tension making them more pleasant to play. They also said that their acoustic abilities improved, etc ... So I decided to give that 335 a change and turn it into something more magical for my taste. I changed first its original Gibson Bridge by a Graphtech Resomax NV PS-8843-C0 https://graphtech.com/collections/resomax-bridges-tune-o-matic And then I removed the Stop Bar and installed a Trapece Tailpiece https://www.thomann.de/gb/abm_1504n_trapeze_tailpiece.htm The installation of a Trapece Tailpiece is not complicated, but it requires a little care not to damage the guitar and checking that everything is well aligned and adjusted Conclusions: By the moment I am really happy with the change and I hope to continue like this
Regards,
Marcus
JDZ
The vast majority of people go the opposite direction under the assumption that the stop tail delivers more sustain. Trapeze is generally considered more appropriate for a full acoustic, like a 330. 335's had a stop tail through early 1965 and not again until 80 or 81. I believe the change was made for cost cutting,as the trapeze would be faster and easier to install than a stop tail.
bum
It's a beautiful guitar for sure my man, congrats on it :)
I'd maybe pop a Towner Bar on, but that may affect the tension in the opposite way from what you are trying to do.
LeftyF2003
So, do you think it plays / sounds better with the trapeze?
