How to rewire/restore a broken P/J Clone Bass? (detailed photos included)
niceties55
I just got a precision/ Jazz clone bass with some wiring issues. Most of the wires are still plugged in and seem to work great, but there are a couple of wires that I have to re-solder.
The black cable comes from the bottom P-Bass pickup. The yellow cable with the white cable coming out of it comes from the bottom J-Bass pickup.
I was wondering if anyone had any wiring diagrams or knows where I should solder the three cables?
I am especially curious about the yellow cable with the small white cable coming out. Where would that go?
LPTDMSV
This is guesswork but here’s where I would start:
The yellow wire is shielded co-ax so I would expect the outer braid to go to ground and the inner white wire to be ‘hot’ for that pickup?
Fender-type pickups usually have two wires (not co-ax) of which one is black and is the ground wire, so I would solder that to ground and see if you get sound.
BadPenguin
Bobby Mahogany
Try to make out "your" diagram and sort out your wires following this SD one.
The P bass pickup is actually two pickups you have to "wire together"
as they go to the pot.
upload_2020-8-2_13-6-42-jpeg.3928798
cmjohnson
The Seymour Duncan website has a fantastic collection of wiring schemes for all kinds of guitars and combinations of pickups and electronics. Many of us bookmark it and refer to it any time we have a wiring question.
