Tough when a bud asks, 'how does my guitar sound?' and you have to say 'dunno, can't hear your guitar through all that wet, warp, and dirt shit, you have piled on it....'
I firmly believe many folks have no clue what their guitar actually sounds like.....
IncorrectHumbuckers pull more on the strings than single-coils because you’ve got twice the magnets in it.
Many people don't seem to realize that adjusting the pole piece height in your pickups can dramatically affect your sound, so I've created this guide to shed light on how to best set the pole piece height on humbucking pickups. This simple adjustment can do wonders to improve clarity and balance the string-to-string output of your guitar. Why did I feel compelled to write this? Because...
Everyone Gets it Wrong!
Well not everyone, but I'm amazed at the amount of misinformation out there regarding setting the pole piece height on humbucker equipped guitars, even from respected manufacturers or magazines. Of course we're talking about music and personal preferences, and you may like to set your pole pieces differently than I recommend here. Even so, I hope that you find good, factual information here that can help you to make informed decisions about setting up your humbuckers.
For the thread I'm going to assume that we're working on a Gibson Les Paul, but the information here will hold true for a variety of types of guitars and humbucking pickups, as long as the humbuckers are passive and have adjustable pole pieces.
Your Guitar Should NOT Sound Muddy or Muffled
An extremely common complaint for Les Pauls, especially the neck pickup, is that they sound "muddy" and unclear. This normally leads people to start doing mods such as changing potentiometers, capacitors, and finally the pickups. However, I have NEVER encountered a Les Paul whose "mud" I couldn't clean up by following the advice in this thread. You may want to change pickups for a variety of reasons, but if you're working with a guitar from a reputable company, you should be able to correct this issue.
Wiring and Electronics
I'm not going to discuss various wiring mods or component changes here. However, I recommend using 50s wiring and 500k or 550k potentiometers in your guitars. Here's one thread about 50s wiring: https://www.mylespaul.com/threads/wiring-library.558/
Single Coils vs Humbuckers
1. Single-coil pickups generally pull much harder on the strings than humbucker pickups because of their design and geometry. This guide is NOT applicable to single coil pickups.
2. Humbuckers can be placed much closer to the strings than single coil pickups because their magnets pull the strings less. That doesn't mean that they sound best super close to the strings, though!
Important Info About Electric Guitar Strings
Here is where I think that most of the misinformation comes from. Your guitar strings are NOT created equally! Each string on your guitar is affected by the magnets underneath it much differently, and therefore, some strings naturally have more output than others! This is because only the solid "core" of the string (not the wound portion) is ferro-magnetic. The amount of output of each of your strings is dependent on the thickness of the solid core (how much ferro-magnetic material it has).
It's counter-intuitive, but the G-string is the loudest of your strings by far. This is because it's the string with the thickest core (though it has no windings, so you can consider the entire string the core). It's hard to find information regarding core thickness from all string manufacturers, but generally speaking, string output (core thickness) for most electric guitar strings goes like this:
Most Output to Least Output: G - Low E=B - A - High E ---- D.
In other words, the G-string has the most output, followed by the Low E and B strings (which are approximately tied depending on string set), then the A string, then the High E, and lastly the D string. The D string has the least output of any string by a large amount for most sets.
What NOT to Do
One of the most common recommendations out there regarding pole piece height is to follow the curvature of the neck. This seems to make sense at first; you are trying to get all of the pole pieces the same distance from the strings. Here is one picture of a pickup that does this:
However, we should know now that this is incorrect! It's not too far off for the three lower strings, but you will have a hugely pronounced G-string (reminiscent of a Stratocaster, and who wants that?!?) and quieter high E string if you set your pole piece heights this way.
Finally, How to Set the Pole Piece Heights on Your Guitar
Taking into account everything above, I believe that this is the best way to setup your humbuckers:
First, you probably want to lower them significantly if you're having problems with mud. You can always raise them higher up later to get more output, but lower pickups in general have more clarity. The treble side should be higher than the bass side by about 1/32". A good starting point is to set the bridge treble side to about 2/32" and the bass side to about 3/32". Now, use your ears to lower the neck pickup (which will naturally be louder at the same height, because the strings vibrate a larger distance here) so that it is at the volume that you want. If you want an approximately equal neck volume to your bridge volume, assuming that you don't have very unbalanced pickups, then the neck pickup will be significantly lower than the bridge. That's OK!
Now that our pickups have approximately the same volume (or whatever amount of imbalance you want), our goal is to set the string-to-string volume. This is done by adjusting the pole piece height. In order to achieve approximately equal string-to-string volume, you need to lower the pole piece of the louder strings and raise the pole pieces of the quieter strings. You probably want to start with all of the pole pieces flush with the cover (or all the same height if you don't have a covered pickup) and work from there. Or do what I do, which is to skip ahead to what I find is almost always the correct solution:
You most likely want the G-string lowest because it is naturally the loudest, and the D-string highest because it's naturally the most quiet. Therefore, I usually set up my pole pieces to roughly go (read from EADGBE, referenced to the pickup cover):
E: Lower than Flush A: Flush D: Higher than Flush G: Lower than Flush B: Flush E: Higher than Flush.
Use this as a starting point, and make small adjustments from there using your ears. When you are completely finished, you will likely have your pole piece heights set something similar to this:
Note that I found this image on Pinterest, and it's the only image I could find that looks close to how I set mine up. However I generally have my first three pole pieces lower than pictured, and my high E is generally a little higher. Of course, YMMV and all of that.
Edit on 3/11:
Raising and Lowering the Pickup vs Pole Pieces, and a Little on How This Works:
Based on some other threads around the forum, I've decided to add a little more info here.
Like many things (gravity, light) that have a source and propagate three dimensionally through space, magnetic fields and the strength of magnetic interaction varies according to the Inverse-Square Law with respect to distance. This means that if you double the distance between two objects, the magnetic force between them becomes 1/4 the original value (weaker by a factor of 4). If you cut the distance to a third (get three times closer), the force becomes nine times stronger! Quadruple the distance and you get a difference in magnetic force of sixteen times the original amount, etc. Clearly the magnetic field varies quite substantially with distance. If you have a pole piece set 4/32" away from a string for instance, and then raise it to 3/32" away, the string experiences a pretty significant increase in strength of the magnetic field.
Anyhow, let's imagine a pickup whose pole pieces are set flush with the slugs. In this case, the slug and pole pieces have essentially the same influence on the strings, as they are the same distance away. If you raise and lower the entire pickup, you increase or decrease the magnetic interaction with the strings in both coils of the humbucker by essentially the same amount. Move the humbucker closer to the strings and you get more output, but often less clarity, and vice versa.
When you raise an individual pole piece, you are increasing the magnetic influence of that pole piece on the string, which makes that string more loud. However the cool thing is, the increase in volume comes primarily from the coil with the adjustable pole piece! This is the coil that surrounds that pole piece, and hence the coil that is affected most strongly by it.
If you raise the pole pieces, the extra output that you get comes mostly from the adjustable coil, and so your humbucker is slightly unbalanced now. Importantly, it is NOT out of phase with the other coil. It's just a little louder, so you don't get any phasing issues. Since you can make one coil interact more strongly with your strings than the other, you can use this to achieve a slight single coil sound. In other words, more clarity and "openness," with less compression. Conversely if you want more output and compression, you can level the pole pieces and raise the entire pickup.
I hope that this guide helps you! Cheers,
ErictheRed.
My goal in doing the foregoing was not to get a “Page”-like tone, but to get three distinct tones from neck, bridge, and middle positions; that can work well under gain or clean and still carry that Les Paul humbucking tone.
Classicplayer
yeah, but I have been undecided as to which bridge pup to select. I decided not to mess with what I have. It is working for my needs.For more of that, you could use two very different pickups, rather than a similar "matched set."
I've saved some of those picture of that guitar belonging to Page; just for the view of the neck pickup. That pickup has been described by a few as being very bright and of a bit higher output that many Gibson necks pickups. That might account for it being so low in its surround. I’m always wondered if the pole pieces were original heights, or if a tech adjusted them. somas to match the few bridge pickups that were put in the guitar over the years.
I have a Seth Lover set and I have lowered the neck pup to where the 6th-string side is just below the surround and the 1st-string side just above it. I only adjusted one D-string pole screw by raising it to balance with the other strings and work a bit better with the Seth bridge. My goal in doing the foregoing was not to get a “Page”-like tone, but to get three distinct tones from neck, bridge, and middle positions; that can work well under gain or clean and still carry that Les Paul humbucking tone.
Classicplayer
Did you lower the neck pickup and raise the screws? That usually adds clarity (depending on where the pokes started from of course).I lowered my neck pickup and all the screws in my Monarkh and it’s still saturated and muddy. I’m looking for other options. Generally this does help a lot though.
Great tip gonna try it today my 2000 r9 I just got I have been messing with pole peices. Like you said I set them up to the radius fretboard. Gonna try your way tonight tks a tonMany people don't seem to realize that adjusting the pole piece height in your pickups can dramatically affect your sound, so I've created this guide to shed light on how to best set the pole piece height on humbucking pickups. This simple adjustment can do wonders to improve clarity and balance the string-to-string output of your guitar. Why did I feel compelled to write this? Because...
What NOT to Do
Edit on 3/11:
ErictheRed.
Following the fretboard radius probably worked pretty well back when electrics all had wound G strings. I'm not a historian, but I don't think that you could buy packs of non-wound G strings until 1968 or even 1970ish in a lot of places. That's a long time for people to become set in their ways and for tradition to kick in.Great tip gonna try it today my 2000 r9 I just got I have been messing with pole peices. Like you said I set them up to the radius fretboard. Gonna try your way tonight tks a ton
