That's a great point. At lower volume, you will need to use more gain than he does to get a similar tone.Marshall style valve amp set to medium gain and on the bright side tonally. (If you're playing at household levels, you will have to bring the gain and bass up somewhat to compensate for the lack of volume)
Slashtone in a nutshell. . .
Les Paul style guitar with Alnico II pups; neck pickup, volume up close to or at max depending on the pickups and the tone rolled back to 4 (ish)
Plate reverb in the effects loop; decay and mix to taste (you want echo not wash)
Get Tim Caswell to mod your Marshall. Or just buy a Caswell #39.
...except that the UYI amp was SIR #34, which is a Frank Levi modded JCM800.
I recall an interview where slash used an explorer on that.. yes.. an explorere for real with the tone own on 0 neck pup.
