- Joined
- Mar 19, 2010
- Messages
- 58,166
- Reaction score
- 206,876
This is very interesting to me because I have a massive chunk of rosewood that I want to make into a TRUE single piece neck for one of my guitars. And by true single piece, I mean that the fretboard will be carved into the neck blank and there woin't be a single piece cut off the blank and glued back on. This requires me to do a skunk stripe Fender style truss rod, but I want to do it with a Gibson, rather than Fender, style top adjustment nut and recess. And with a Gibson style back angled headstock as well.
The only piece I want glued into the neck is the skunk stripe, and I want that to be made from extra material off the neck blank, which is more than adquate in size to provide that.
Since the blank is rectangular and uncut, the truss rod access cavity can be drilled while the blank is in its current shape, and then slice the headstock angle off after the fact.
But this is one shot. I can't screw it up. I may hire someone else who has experience installing F style truss rods to do the truss rod installation work.
LtDave32, would you be interested in taking this on?
On this.. I've built many a one-piece, skunk stripe neck. The rod goes in curved, with the apex of the curved rod channel having a depth of .555 . A three degree hole is drilled on both ends to match the curvature of the rod. The skunk stripe is curved as well on the side which rests on the TR itself. This is to ensure there is no movement.
The rod itself is pure simplicity. There is an adjustment barrel nut on the bottom end, and a "bottlecap" crown with teeth on the headstock end. One normally pushes the threaded end though the angled headstock hole, threads it along the curve of the truss rod channel, then inserts the threaded end into the bottom hole on at the heel.
There is a block between the truss rod channel and the ends of the neck on both ends. The bottlecap end gets tapped firmly into that block (to keep it from turning) through the access hole, then a walnut plug gets tapped in, glued and cut off. This is so the bottecap end can't lose grip or back out.
The barrel nut and washer rest on the block in the heel end. Tightening the nut, since the rod is curved and has nowhere to go but straight, pulls back on the neck, taking out the relief.
I see no reason whatsoever that this procedure cannot be reversed with the adjusting "barrel" nut swapped out with a bullet type adjust nut and poking through the access hole, or just leaving the barrel nut in the access hole and adjusting it with a screwdriver. However, a plug with a hole drilled is probably not the way to go, it's not big enough. You'd have to use a larger hole to get the adjustment tool in.
But as I suggested, show me some pics and descriptions, or point me to the thread if it has all that, and I'd be happy to check it out.
