How many amps can I daisy chain via Line Out to Line In?
efstop
Hypothetically, of course. I have several with one or the other.
This is just something to chew on as a Friday topic.
I also have two cheap 5W amps with dual inputs, so there's a possibility of chaining those two to a third, right?
Buffalo
It depends on the amplifiers used, but usually if the line out signal is conditioned(amplified) in the amp, as many as you want until the noise adds up too much on the signal.
CerebralGasket
+4 dBu or -10 dBV ?
You probably want to make certain they are all the same line levels.
Some have switch to change between levels.
johnnyesquire
Ever try going through the board??
