How easily does an ABR-1 tilt?
LysanderSky
Hi there,
I use 10-52 (Ernie Ball Skinny Top Heavy Bottom) strings, I don't plan on changing that...
Now the saddle on my low E (the fat 52 gauge one) is maxed out in the neck direction for intonation and touching the the back of the bridge.
The other strings clear the bridge.
I don't really want to raise the tailpiece from the current position either, unless I reaaallly have to.
Do you think the low E could cause my bridge to tilt eventually? When would 'eventually' be?
Thank you.
tnt423
Shouldn't be a problem unless your wheels are way high on the studs. If they are you might see some tilt after a few years. Just keep an eye on it and watch for the bridge sagging in the middle.
LysanderSky
Thanks guys, that was quick!
I've top-wrapped before, don't mind it but prefer string-through.
My bridge isn't really high (about 6 mm), so I guess it should be ok.
Thanks again.
Stephmon
If you need a bit more travel on that saddle, turn it 180 degrees (if it isn't already).
