Never!tone pots, use 'em.
Amp: 50-watt EVH 5150 III combo (Treble - 2 o'clock; Mids - 12 o'clock; Bass - 2 o'clock; Presence 1 o'clock; Gain - 3 o'clock-ish)
Tone pots, use 'em.
I'm with the X...Tone controls..0-10
Never!
Chris B and Lefty-
Can you guys elaborate on any mic'ing troubles this may or may not cause?
One of the commenters on the video said this:
"Beam Blockers really do help with the dispersion. But there's a down side too. If you need to close-mic the speaker (for live sound reinforcement or whatever), the mic hears a horrible sound when a Beam Blocker is in front of the speaker. It doesn't matter if you aim the mic around the side of the Beam Blocker either. It just doesn't ever sound good to that close mic. Of course, it's not a problem if you have a way to send your signal through a direct injection (Palmer PDI or equivalent). But something to consider."
I mic this amp all the time for live gigs. I use a floor stand with an SM-57 and I set the mic to the side of the cone (edge of the beam blocker). If anything it sounds better than it did before - warmer with better range.
I'm not sure if this is what you are talking about but with really high gain amps any guitar I have with a TOM bridge has really shrill harmonic overtones that are caused by the strings ringing out behind the nut and behind the bridge. My EVH 5150-3 was the most sensitive to this issue. I put foam between my tailpiece and bridge and a bit under the strings behind the nut. Live it looks like crap but tightens your sound considerably.
No offense taken. I'm not able to record at this time. I've been playing over 30 years. My amp is new. I hold my pick at about a 30-degree angle to the strings with a downward/upward slant depending on the direction I'm going (ascending/descending). Red Bear puts a pretty good bevel on the edge of their picks so that there's more surface hitting the string than you would normally see when holding the pick the way I do. As stated, I've never had this happen to this degree.
If you're using the red channel on the EVH, you may be able to dial the gain back a bit. I have the 100 watt version, and I find a pretty sensitive connection between the gain and the presence controls.
Whenever I pick an individual note, I get a shrill ice-pick sound. It's very high-pitched. Is there anything I can do to completely eliminate this via EQ? It's not something I've ever had to deal with on this level.
My setup for better perspective:
Guitar: 2016 Gibson Les Paul Custom w/Dirty Fingers in the bridge
Pedal(s): Ibanez Tube Screamer
Strings: Ernie Ball Regular Slinky (.010)
Picks: Red Bear Guthrie Govan or Big Jazzer (Extra Heavy - 2.0mm)
Thanks in advance
Tone pots, use 'em.
Dirty Fingers are high-output ceramic pickups.
..that'd probably be where I look first.
(ime ceramic pups are known for shrillness/ice-picking)
Good luck.
