how do you like to set your LP for clean rhythm tone
  • Thread starter e44crowe
e44crowe
I have a Gibson Studio Les Paul that I play through a Fender Blues Jr.
My Tele seems easier to get a good clear and clean rhythm tone out of the BJ.
Any tips on how you set your LP for a good clear and clean rhythm tone?
Thanks!
ADP
Master at 12, Volume at 8 - 8.5, Dial the bass off and give it some Treble, the most important thing about a Blues Junior though is having the Master full on!
MikeyTheCat
I've never been a fan of the clean bridge humbucker sound, so I either do what RichBrew posted or these days I switch to the P-90 on my bridge P-Rails.
paco1976
I like bass and treble at 9 mids at 4. Master at twelve, sand you control with the volume.
Bristol Posse
Depends on a lot of things
There are 3 versions of the Blues Jr each with some differences in the voicing and circuit.
They also use different speakers too
It also depends on how loud you're playing too as the low end can get pretty farty sounding as you get loud.
If it's a stock amp with no mods and you're talking gig volumes then you'll probably need to roll off a lot of the bass and then tweak the mids and treble to taste. I used to keep the bass below 4 for gig volumes on mine
If this is your serious gigging amp you may want to consider a couple of easy mods to stiffen the power and maybe even add an after market output transformer.
Even with everything else stock, this will really tighten up the low end and get rid of that farty sounding low end mud and sag that these amps can suffer from
YMMV
Matt
paco1976
YMMV
Matt
I agree.
It is great amp, I love it, but for gig purposes it depends on the venue or if you use a mic or not. If you need a high volume it is going to distort, you can't avoid that.
Master at 12 and Volume at 5/6 is distorting already. You need a really clean sound better use a mic.
Shawn Lutz
I use the neck pickup with the volume rolled back a bit. I like amps that react well to the guitars volume knob for the versatility of gain on the lead channel. Real super clean I use the clean channel on multi ch heads. I still use the neck pickup and roll off the guitars volume
X–Ray
Cowbell by Misadventure
My rule of thumb:
Set whatever amp I'm using volume up to the point it begins to get dirty/crunchy, then roll back the guitar volume
I use an overdrive pedal (Rivera Blues Shaman) for serious gain
This way I can get a punchy and clean rhythm tone and then add gain via overdrive when so inclined
e44crowe
YMMV
Matt
I have a tweed blues junior with the Jensen speaker. Gig volume clean is what I'm after.
Bristol Posse
How big are the venues you are playing
Jensen c12n is around 98dB sensitivity, you can get a good speaker with 102-103 dB sensitivity which will give you more volume at the same settings (ie louder cleans)
Something like a Mullard or RCA 12AX7 tube in V1 preamp might give you a little more clean gain on the preamp/volume (I don't get preamp breakup 'til i get to 8 on the volume on mine with an NOS RCA 12AX7A in there), and higher headroom EL84 in the power section may extend your clean volume a hair
But when all is said and done it's a 15 watt amp and loud, clean gig volumes and 15 watt amps don't often go toogether
You can mod it with a new power transformer to run 6v6 output tubes and push around 30 watts but at that point it may be more expedient (and safer) to just buy a more powerful amp
vindibona1
Thanks!
I love my LP's as much as the next guy. But in terms of clean rhythm, you're not going to beat your Tele for the sound. Humbuckers sound like... well.. humbuckers. My LP Custom has coil splitting so I'm a bit ahead of the game there, but my Tele just has that certain personality.
