bosnialove
- Joined
- Dec 8, 2011
- Messages
- 3,202
- Reaction score
- 2,451
My name is going onto the headstock anyway, so even when I want I won't be able to sell it.
The problem with hide glue is that EVENTUALLY, the joint will disasemble itself whether you want it to or not. When it completely dries out, it basically turns to dust.
Glues such as original Titebond I can be disassembled, but won't cause self-disassembly like hide glue does.
I reserve hide glue for instruments of the violin family.
Sorry, but that's just not true. Other than the Gibson name and logo and the shape of the headstock, and (arguably) the truss rod cover, Gibson has no surviving IP rights in the Les Paul at all.
I'm going to give you my unvarnished opinion. The guitar you're having made for you is not an LP, it's a copy, a knockoff, a clone. And it may be, depending on how close it is to the original design, an illegal product that infringes on Gibson copyrights registered worldwide. It's pointless to try to be authentic to the vintage spec because it's not an authentic instrument. So there isn't ANY reason to use hide glue. Use modern glues that are BETTER.
To extend upon my opinion, and possibly generate some bad vibes among this community, I will say that I have seen many people making more or less faithful copies of classic LPs, some being more faithful to the original than others, and in the case of the most accurate copies, you are basically telling Gibson that you have no respect for Gibson's intellectual property rights, which I find ironic and amusing since you seem to have so much respect for the guitar design itself. You respect the guitar, but by going to great lengths to copy it in every smallest detail. you are completely disrespecting the company that made it and owns the exclusive legal rights to make it.
I consider making clones to be a waste of a luthier's skills. Be original. If you're good enough to make an accurate clone, you should be able to come up with something that hasn't been done already, maybe tens or hundreds of thousands of times.
Making one or two as skill builders seems to be pretty much a standard practice for luthiers who are learning how to do it. That's fine, I've done it myself. But it seems that there are people who try to make a career out of repetitively copying a product that they have no legal authority to be copying, and to me that is just wrong and unethical. Change SOMETHING about the guitar under construction that marks it as being identifiably different from the original. I may do fairly close body shape copies of PRS guitars, but I change around enough things that you would not mistake my guitar for PRS products. Even then, I'm trying to come up with new designs that are even farther away from the PRS shapes without getting out of my aesthetic comfort zone.
While I totally support your right to express an opinion, your comments re the rights & wrongs of Replicas are totally off topic. You're not really adding anything to help answer the questions B has asked help on...we are not here to debate the legalese. We are here to discuss the merits of various Glue options.
As Barnaby has pointed out, in a manner of speaking, the guitar is a complex system and the effects of any one construction element or process can often be impossible to quantify. I think what we strive for or look for is the gestalt of the instrument.I know of at least one luthier who has a large microwave used for drying out backs and sides for acoustics, and that may do something.![]()
Actually, all instruments made with hide glue (including all members of the violin family) do require maintenance and regluing from time to time as the hide glue DOES dry out, weaken, and eventually starts separating at the seams. There's not a 300 year old violin in the world that's still intact that hasn't had glue joints redone. It's routine maintenance.
I've made enough of a study of violin construction and repair to be quite sure of this. There's simply no doubt about it.
Anyways, how are those old violins put together, fully with hide glue?
Sorry but that's just not true. There are plenty of pieces of fine furniture on estates in the UK which haven't been touched in 100s of years and the glue joints are just as strong as the day they were made. I know this because I'm actively involved with them, not to mention plenty of antique instruments. What you are seeing is either improperly prepared joints, improperly prepared glue or mistreated instruments.
Your point is moot anyway as you can not offer a suitable alternative which is guaranteed to hold up over 100s of years, as Titebone, PVA or Epoxies simply haven't been around long enough to be tested in the way which Hide Glue has. It seems completely bizarre to me why you would be against using the only glue which has been tested over 100 if not thousands of years and comes out on top in a number of different uses while standing the tests of time....and a lot of it!
At the end of the day the glue is not particularly important (within reason), it's the joint.
I think i'll choose for hide glue and acetonebfor the little stuff.
