I would seek refund from seller for the damage. Its ultimately his/her responsibility to pack guitar and ship.
I would assist the buyer if they needed assistance with the claim but I would not personally be filing the claim. IMO that is the buyers responsibility
No it is the sellers responsibility to deliver the goods as they were advertised.
You can Google the federal consumer protection laws but basically you have the right to refuse any item delivered to you within a reasonable time period (usually 72 hours) if you have determined it to be defective or not as described. At that point the seller must provide a refund and return shipping unless you make other arrangements such as a partial refund or repair.
It was late last night mixed my words.
Of course it's the sellers responsibility.
No problem. But it was good to mention anyway because a lot of buyers are not aware of their rights when things do not go well with a purchase.
Cheers.
Hey all. Picked up a nice R8 off the forums here and I love it. Problem is, USPS took 8 days to deliver a 3 day priority package and managed to bang it enough to crack all the knobs, the bridge tone knob seems now shorter than the rest, and seems like it has very sporadic effect through the pot sweep. There are some cracks in the lacquer between the pots(looks like relic checking).
I’m going to file a claim but they want estimates for repairs. I live 2-3 hours away from any luthier shops. I don’t trust the local shops.
I assume I shod get a quote to fix the knobs and pots, and an estimate of devaluation due to cracking. Any thoughts on who else I could get a quote from? Maybe someone on the internet??? Reputable?
Edit pics added. Sorry i haven’t had time to give her a proper photo shoot
If this is your 1st Historic the 'sporadic' volume control you mention may just be the nature of audio taper pots. They don't have a uniform 1-10 sweep like linear taper pots. Unless something is obviously wrong with them, either physically or they simply don't function, there's no benefit in replacing them. Only the effort and expense.
Knobs also do not sit perfectly level with each other due to the curvature of the top and relative thickness. Plus they may sit higher or lower on the pot shaft.
Knobs are easy and cheap to replace. Those inner cracks are common, the outer ones less so.
The small finish crack/check lines are unfortunate but they do happen naturally over time with heat/humidty, or possibly over tightened nut or possibly contact as you suggest. They may have been there already and hard to see in pictures except at a certain angle. How much they bother you is your decision.
Lovely looking guitar.
Daz
This.USPS is the absolute worst choice to ship anything of value. Consider yourself fortunate that you even received it in the first place.
Not sure if i'm reading you right, long shaft are not standard on reissuesI have owned, i have had nine over the years 2004 to present, all have been short shaft.That's absolutely normal on a reissue. Those are long shaft pots.
I would also claim from courier, if they accepted insurance payment, they delivered a damaged guitar, its not cheap to expect it to be made right.
I was under the impression that they used long shafts cause the knobs float higher above the body than on a standard run from the mill lp.
But why is it then that the knobs lay higher?There are 3 heights typically used in guitars - long shafts on regular Gibson models, historic height (short shaft) like on a '59 Les Paul, and reguar short shaft like on a Strat.
Because the control cavity on a historic Les Paul is routed so that the maple cap is very thin where the pots are installed. The guitars with the knobs closer to the body are because they have added the washer to the pot to adjust the height correctly. They are definetely not long shaft pots. I have not seen long shafts on any historic Les Paul.
