RobStark
- Joined
- Dec 4, 2014
- Messages
- 30
- Reaction score
- 13
Hi Everyone,
I recentlty joined the forums, although I've been lurking on here for quite a while. Well, I always try and research my questions throroughly before posting. I am not looking for a short cut; I put time and effort into my research but sometimes after days of trying to find a very specfic peice of information, only then will I resort to asking the professionals and non-professionals who have more experience than me.
Anyway, on to my question:
So, I am having a hard time understanding in what order and WHY (in regards to the steps taken when building a les paul style guitar) do you route the pickup cavities and neck pocket? Now hang on a sec... It isn't just a simple question like that, let me explain: I am asking because I have gotten such conflicting answers when watching and reading about other peoples builds, regardless if they are professional luthiers or amatuers such as myself doing their first build. Also, the angle of each has a lot to do with the order of things in my mind because it would seem to ME to make the most sense to just route everything out in the begining while the board is still square (prior to cutting the body out but after tracing it from template) and also it seems easier while the board is still flat (not carved/arched yet). But this logic must be flawed because I see people cutting out the body first, carving it, and THEN routing out the cavities.
But also have also seen so many different builds do a mixture of those steps in all different orders (some route out wire channel, then cut out body, then cut neck pocket, then carve, then route pickup cavities, etc...). Pretty much, mix those steps up randomely in every order possible and I've seen a video or read a build in that order.
So this is so confusing to me, but I seem to be the only one bothered/confused by this so what am I missing? I realize I still lack some of the basic woodworking fundamentals/theory and maybe if i had a better understanding I would already know the answer but I am on a quest for information and this is one obstacle in my way.
Can someone...ANYONE.. shed some light on WHY they do their particular process and also why I see so many different ways?
Also, i once read someone on here saying "if installing humbuckers in your build, you don't need to worry about routing an angle in the bottom of the cavity since humbuckera are attached by the pickup rings and they attach to the body itself (the plane I believe they call it?) And so only the " plane" needs to be angled. Is that true,?
OK thank you and sorry for the long post. Any info or direction to a source would be much appreciated.
