HELP: PICKUP WIRING GURUS - Need to install a piezo bridge with a toggle switch
czerpa
Hi. I have a Gibson Les Paul with the standard wiring configuration as found here (first pic):
LES PAUL WIRING
I have a Power Bridge (TuneOMatic) (basically a "piezo" pickup to get Acoustic tones). The installation sheet/diagram is here:
POWERBRIDGE
What I NEED is just to be able to install one 2-way toggle switch (on/off) so that the Piezo pickup signal blends with the the magnetic pickup signal (magnetic > piezo > output jack) when "ON". Then, when in the "OFF" position, the signal routing is AS USUAL (i.e. no piezo whatsoever, just magnetic pickup action).
I need a recommended WIRING scheme/diagram. Thanks for your help!!!
C
