Help building this pedal?
Oldskoolrob
Hi guys,
I'm mucking around with going stereo. One problem I'm having is with my rhythm vs solo levels. I can't justify the expense of a stereo EQ pedal (that's how I boost my mono signal) but I was thinking I could put a couple of volume post in a pedal box - so I'd be cutting signal for rhthym and having the unity signal for solos. Any advice on pot value and wether or not to use a treble bleed (and if so, which design and values?). I've never built a pedal before so I see this as a good project that should be 'at my level'. I can solder....kind of. I'd like to have independent volume controls, true stereo signal.
Thoughts?
scooter500
Buy a pedal kit with instructions. That's what I'd do as a solid first step.
Oldskoolrob
Where would I look to see if this kind of pedal exists in kit form?
