Help ! Both pick ups only make sound in neck position!!
kenobeenz
:rofl:this is driving me crazy as I have pulled everything out twice and rewired it ,I have done over 10 guitar wiring jobs exactly like this ,I've checked continuity, tried different switches,different pots ,my soldering looks bright and solid ..In really curious to know why both pick ups would play only in neck position,they are wired to different pots ,switch less are wired to different pots too.Its crazy.
Either you have something touching the 'leaves' of the switch, or perhaps the physical switch function has been compromised.
Oh.....and there are at least a few different 3-way switch orientations I've seen. Such that you cannot wire a Gibson type 3-way just by following the pattern of any other one you've used.
