Helix HX Edit 2.81 is out.
James R
Downloading as we speak. Hopefully it will resolve the constant patch updating on boot up.
I haven’t noticed a single issue with 2.8, but I’ll still update sometime this week.
Thanks for the heads up!
drew365
I did it just for the hey. No problems.
KenG
Did you do the factory preset update when you loaded 2.8?
Pop1655
Just read 2.81 has a different installer. Is that right?
drew365
You always need to download and install the HX Edit update first, which will update the installer. Then use the new Updater to update the hardware Helix. Trying to update the Helix hardware without updating HX Edit/Updater first will cause problems and wasted time.
Pop1655
I did for 2.80. Don’t know that I knew it was an every time thing. Thanks.
Pop1655
2.81 for dummies
How many clicks do I have to make?
Editor
Download
New pre sets
Drivers
drew365
2.81 for dummies
Editor
Download
New pre sets
Drivers
Download and update the HX Editor
Connect your Helix to the computer and use Updater to update the Helix
If you want the new factory presets, restart while holding buttons 7 & 8, the bottom left buttons
Drivers are included in the first file for the new HX Editor
Mr Insane
I haven't found any problems so far with 2.8, how important is this update?
CaptainT
I have many problems after 2.81.
No sound after changing presets.
Huge delay when changing presets.
Sometimes the knobs don't work:(
KenG
Go on the "other" forum where Line6 frequents and raise a ticket.
CaptainT
@KenG I found one issue to be the "Global Settings" of the joystick encoder. It has to be set to "Model" to make the joystick work properly. It´s better now, but still not perfect.
I´ll try a factory reset and reinstall of the update. If this doesn´t work, I´ll try your solution @KenG.
Thanks, I didn´t know Line 6 is active "there" :)
