I used to think wood wasn’t that important, but I’m beginning to realise that it might be the biggest thing. Otherwise why would the same type of guitars sound so different?+1 on what Big Do and others have said about it has to sing acoustically.
Weight seems to not be a reliable predictor/indicator of how a guitar is going to sound.
I bought a LP Special about 6 months ago that was hand-picked from among 3 of same year/model (at Wildwood Guitars.) It was the most resonant acoustically and most balanced across the tone spectrum. To my surprise and the surprise of the the guy doing the comparison it was the featherweight from the 3 Specials - weighing only 7 pounds. I has a nice chunky neck on it, yet is not neck-heavy. A perfect guitar!
One thing that I think contributes more to a guitar's tone than people realize is the neck.
I've learned that chunkier necks produce warmer tone, while thin necks produce brighter tone. A luthier explained this to me as follows: "... other than the strings the only part of a guitar that moves when you're playing it is the neck. which actually flexes as the strings vibrate... if you took a high speed video of the side view of the guitar's neck and strummed the strings (then slowed down the video) you would see the neck flexing up & down."
To build on this...the two points of tonal transfer into a guitar's body are the bridge/tailpiece and the neck joint.
The bridge/tailpiece are the source of the high end tones going into the guitar body.
The neck and neck joint are the source of the low end.
From here things get complicated when you consider all the variables in bridge/tailpiece formula and same for the construction of the neck. Everything matters to some extent, and it is the combination of how all the parts interplay that make for a truly musical sounding instrument.... but... all of it can get flushed down the toilet if the guitar body is dead tone-sucking crap wood.
...um... what were we talking about?
Oh yeah! Guitar weight and tone!
Not as big of a factor as I used to think it was.
As much as it pains me deep down....way deep....no, deeper than that, I must agree with Vic.In my experience, weight has nothing to do with tone.
I got around to weighing the TRAD, topped out at 9.8 lbs. Wasn't going to be an issue either way as I am sitting anyway but was curious. I like it the longer I have it. I think it is just an all around guitar for blues, jazz, rock. Put an OD or DS pedal in front and you can have a lot of fun with it.Much older, but I have a 2008 Traditional (9lbs. 4oz.) that I’m very pleased with, bought it used a few years ago & it had some after market mods including stainless frets & new bridge/electronics, loved the frets but changed out the bridge & tailpiece to Faber & a harness made by Jonesyblues with Mojotone ‘59 Clone low output pickups, this one probably gets played more than any of the others including my CS models, partially because I’m less worried about leaving it out & it’s close at hand, really a good solid guitar that is well worth the money I have into it.
Sounds like yours is a good one too, and they come stock as good guitars, no need to change anything & I think Gibson USA got it right with the Traditional, have really liked the few that I’ve played & a gold top would be nice someday.
Hope yours works out well for you, sounds like you’re off to a good start with it.![]()
