Has anyone ever used one of these buffers?
fatdaddypreacher
seems a little fast for lacquer to me. it seems as though under 1000 rpm comes to mind. i think i had the recomendations from somewhere on here and used a motor and step down pullies to build one. maybe 800 rpm is what i'm running. i hope others weigh in.
fatdaddypreacher
now that i think about it, i bought one from harbor freight virtually identical to that one, as i only build one or two guitars a year....at best. i basically used it for the shafts, and mounted in to a piece of plywood, and used another small motor with properly sized pullies to run the shaft on the 'buffer'. works great.
  • Like
Reactions: Who
cmjohnson
1750 rpm with buffs that size is anything BUT "low speed". I'd never recommend that on a lacquer finish, and even on a urethane automotive finish I'd use it with great care and never let heat build up.
If you want a serious buffer for guitar work, get the StewMac guitar buffer sold by Stewart Macdonald. It's not cheap but it's the right tool for the job.
Matt_21
Ive got something similar. Got it from Harbour Freight. I plug it into a router speed control and dial down the speed that way. I don't know if that's "right" but it's still working.
Never used it on guitars though.
solteroblues
In my limited experience, I think it is commonly done that way because of the different hardness of the materials. I think you can wind up wavy on the wood as you sand over the harder shell. If the wood is already radiused, you can quickly bring the shell down flush with a file and then use a radius block to blend it all together and remove scratches.
I don't build enough guitars to justify over $800 for the SM buffer. I thought about this plus a speed controller of some kind, but I'm afraid a speed controller on a motor that wasn't built for that will burn the motor up after a bit.
Roxy13
Does that Rikon buffer come with a motor? If not you slow down your motor using the correct size pulleys.
LtDave32
Desert Star Guitars
rikon buffer
Long shaft "low-speed" buffer. It's only 1/2 hp running at 1750 rpm. Would this work for buffing a guitar? Anyone have one?
I use one very similar. I have the Shop Fox. Very similar to that .
You know you have to supply a motor and pulley for the motor..
LtDave32
Desert Star Guitars
I use a cooler motor rated at 1750, and in the back of the buffing unit there are 3 different pulleys to control speed . Works like a charm. Stew Mac overcharges for the same thing. I use this on all guitars I build in my shop, and they all have nitro finishes
cmjohnson
Pulleys are cheap. Pillow blocks and bearings are cheap. Take your 1750 RPM motor, put a step pulley on it, get the hardware you need, build your own pulley driven buffer head, connected via a drive belt.
Joe Desperado
A router speed control would probably work. I think the speed control works by lowering the frequency but not the voltage. I’m not an electrical engineer but that is my understanding.
LtDave32
Desert Star Guitars
Since it has its own motor, you don't likely need anything else. 1750 and 1/2 horse is just fine.
I use 10" wheels on mine, two per side, and get them from McMaster-Carr.
lowatter
I don't even have a buffer setup but I would think as Dave mentioned to use larger diameter buffing wheels. at least 10 and probably better off with 12". The larger the diameter the slower the outer perimeter speed. I'm pretty sure that the buffing wheels can be pretty pricey.
fatdaddypreacher
i did infact change to 10 inch wheels, and the main reason i will go to 12 one day....if i can find them...is for more clearance. 8 inch wheels will put a guitar dangerously close to the grinder body in certain positions. it's bad enough with 10,s, but one needs to be very careful when they get to this stage of a build anyway. oops isn't a word one likes to mutter at this stage.
Duane.S
Like others have said, I think that the rikon buffer will be way too fast for lacquer. A quick calculation says 3665 Surface Feet Per Minute. From what I've read you will want the buffs to turn about 2500 SFPM for lacquer.
I would recommend getting a Shop Fox buffer arbor and motor and build your own.
The diameter of the buffs become part of the equation for finding the correct ratio of pullies from the motor to the shaft. Larger buffs give you more room to get into tight areas like cutaways, I use 14" (I use this arbor and it recommends 10" but I have been running 14" for years with no problem). So about 700 rpm at the shaft with 14" buffs
Jescar is a good source for buffs and they carry Menzerma buffing compounds which I like. Always use different buffs for each grade of compound. Doubling the buffs will make the the point of contact larger so that you don't heat finish as easily and single buff will get into tight areas.
LtDave32
Desert Star Guitars
I've got a ShopFox arbor, three pulleys, belt on the largest pulley for the slowest speed. The factory says 8-inch, but it easily accommodates 10 inch. the buffing wheels are thin at 1/2 inch each, so you have to spend a bit and put multiple wheels on each side to build that thickness. I use one side for medium compound, the other side for superfine finish compound. At the end, I'll use a hand-held with carnival wax,. Then another super soft bonnet with nothing .
LtDave32
Desert Star Guitars
I've got the shop fox. Superb machine . I love it
