GREENY inspired Soap Bar P-90 set for Classic Rock and Blues Made in USA by Jonesyblues
jonesy
GLOBAL WIRING GURU
MLP Vendor
VIDEO DEMOS of JONESYBLUES PICKUPS & WIRING
More details at my Jonesyblues.com website or feel free to give me a call anytime at 574.540.9777
My Hybrid Pro Player set in a Gibson Flying V - PAF neck, Humbucker bridge
Epiphone Black Beauty with Duncan's and one of my MSP III wiring harnesses
Les Paul with my Rock Humbucker in the neck and Bill Lawrence 900XL in the bridge
Short demo of my '59 Handwound '59 Formvar Strat pickups
jonesy
GLOBAL WIRING GURU
MLP Vendor
Gibson Les Paul Standard Unburst with Jonesyblues.com Upgrades. CTS550K pots, Mojo .022 caps and 50s wiring circuit. Video shows how well these volume pots in my harness control the amp output.
jonesy
GLOBAL WIRING GURU
MLP Vendor
Video Demo: I upgraded all the electronics in this 2020 Gibson Les Paul Classic and installed a set of of My Rock Humbuckers and one of my trouble free custom 21 Tone Jimmy Page wiring. (10 years in development)
Jonesyblues 21 tone Jimmy Page wiring
Rock Humbuckers from Jonesyblues USA
More details at my Jonesyblues.com website about these upgrades.
Feel free to call me anytime if you have any questions or need help with your project.
jonesy
GLOBAL WIRING GURU
MLP Vendor
Tele Build #3 complete my hand wound 1950B Hot Rod Hot Single coils with a very "Gibson-ish" sounding neck pickup at 8.8K ohms and 12 K bridge pickup. More info at my Jonesyblues.com website on the 1950 pickups
jonesy
GLOBAL WIRING GURU
MLP Vendor
21 Tone Jimmy Page Wiring Package by Jonesyblues
10 years of development have gone into perfecting my version of the Jimmy Page wiring. The 21 tone version comes with 4 CTS black molded push pull pots and the 50s wiring circuit. No dead spots or glitches and extension leads for switch and pickups are color coded and labeled. This makes it easier to make all your connections without soldering directly to the pots. Comes with instructions for fast, easy installation. One of my customers described it as being "Idiot Proof", his words not mine...Lol
This package also includes a Switchcraft toggle switch and output jack which is needed with this harness. Your stock toggle switch will not work with the 21 Tone JP rig and may cause issues if you try to use it. Use drop down menu to choose options.
NOTE: All the CTS pots I use require a 3/8" mounting hole and 24 fine spline knobs. Import guitars will need to have the holes reamed out and purchase new US sized knobs. Stock metric knobs will not fit the CTS pots.
*Feel free to contact me if you have any questions or need help
Jonesyblues.com NEW Improved 21 Tone Jimmy Page Wiring
Push Pull Functions
NV= Neck Volume
NT= Neck Tone
BV= Bridge Volume
BT= Bridge Tone
HB= Full humbucker
Switch set to Bridge position (treble)
1. All controls down-bridge pu in full HB Mode
2. BV pulled out-bridge pu screw coil is on
3. BV,BT pulled out-bridge pu is split and slug coil is on
Switch set to Middle position
4. All controls down-neck HB and bridge HB are parallel in phase
5. BT pulled up-neck HB and bridge HB pu's are parallel out of phase
6. BV pulled up-neck HB and bridge screw coil is on pu's are parallel in phase
7. BV,BT pulled out-neck HB and bridge slug coil on pu's are parallel out phase
8. NV pulled up-neck screw coil is on and bridge HB pu's are parallel in phase
9. NV,BT pulled up-neck screw coil is on, bridge HB pu's are parallel out of phase
10. NV,BV pulled out-Neck screw coil on, bridge screw coil on pu's are parallel in phase
11. NV,BV,BT pulled out-neck screw coil is on, bridge slug coil is on pu's are parallel out of phase
Switch set to Neck position (rhythm)
12. All controls down-neck is in full HB mode
13. NV pulled out-neck screw coil is on
14. NT pulled out-neck HB and bride HB series in phase
15. NT,BT pulled out-neck HB and bridge HB series out of phase
16. NT,BV pulled out-neck HB and bridge slug coil is on pu's are series in phase
17. NT,BV, BT neck HB and bridge slug coil is on pu's are series out of phase
18. NV,NT pulled out-neck screw coil is on bridge HB pu's are series in phase
19. NV,NT,BT pulled out-neck screw coil is on bridge HB pu's are series out of phase
20. NV,NT,BV-neck screw coil is on bridge screw coil is on pu's are series in phase
21. NV,NT,BV,BT-neck screw coil is on bridge screw coil is on pu's are series out of phase
21 Tone Jimmy Page Wiring at Jonesyblues.com
