Yes, '81 Tokai ES 100 were finished in NitroSadly, I can't see/play either in person. The tokai supposedly has kloppmann PAF replicas which makes it a tad more interesting. I'd be curious to know if that Tokai was finished in nitro.
I'd love an SA1200 or SA59-120 but $4000 seems pretty steep considering the fact that most Grecos go for less than their Gibson CS equivalents.Or, an earlier Greco SA900, or even SA1200.
Yeah I could kinda tell by the lack of mickey mouse ears on SA-90 models, as well as the more 60s looking sunburst with less black applied to the sides.Isn't the SA-90 from 1991 identical to an early 1980s SA-900, that is, a true copy with mahogany neck as opposed to maple neck of the late 70s SA-900 copies? From 1982 onwards, Greco skipped one zero and added the reference year (59 or 61 for 1959 or 1961 ES-335 copies). SA-61-90 for example in 1982. I assume, the SA-90 is a 1961 copy. The neck is rather thick. I can measure it. The guitar is available here: https://www.ebay-kleinanzeigen.de/s-anzeige/greco-sa-90-es-335-mij-nitro-finish/2054214979-74-3408
The neck is quite right, I would say. Not too thick and definitely not thin. (The neck on my 1964 ES-355 is way thinner.) I measure in the 1th fret: width 4,32cm (1.70"), thickness 2,12cm (.83"). The weight is 3,6kg.Late 80s / early 90s Grecos were good but I think the necks tended to be thinner than the early 80s ones. I think that Greco is from 91 BTW
Depends on your preference. I had an RS900 from '89 with a relative thin neck but my EGC1000 is closer to a '58 profile. I've heard others here mention that early 80s had the thicker necks...The neck is quite right, I would say. Not too thick and definitely not thin. (The neck on my 1964 ES-355 is way thinner.) I measure in the 1th fret: width 4,32cm (1.70"), thickness 2,12cm (.83"). The weight is 3,6kg.
Yes, the guitar is from 1991.
