"Good Years" and "Bad Years" for Gibson Les Pauls
flamesarewicked
For me it’s been about specs... I’d rather a 13 traditional over say a 17 model. I’ve had both and I prefer the neck of the 13.. both were good guitars with good fit and finish.. I did like the 57s in the 13 more so than the BB in the 17. The early 2000s models were pretty good in my experience.. I’ve had 3 classics and one standard from that era.... I’ve owned a Blueberry 17 Standard and I liked it a lot.. wound up trading it for a 86 Custom.. I didn’t use the push pulls on the 17 but it wouldn’t deter me from owning another..
I will say I have no interest in 15s because of the headstock logo primarily. I can deal with the rest of its differences.. I owned a 18 LP HP which had the same style nut and similar wider neck.. if I was more of a shredder I probably would of appreciated it more....
I’ve been lucky I guess.. I haven’t owned a Gibson that I would call bad.. as in beyond a good setup and pickup swap. Those two factors are really easily fixed and vary person to person .. what I don’t care for is when people who don’t own one go out of their way to give Gibson shit over build quality, over priced, etc.. ah well that’s a whole other can of worms that doesn’t need to be opened but anyhow... if I based my experience with Gibson on 15 min test drives at GC with a horrible setup with dead ass strings, I wouldn’t own one either..sadly there’s a lot who do use that small glimpse as a deciding factor.. but I’ve been playing long enough to know whether it just needs a setup or there’s more to it that a setup won’t remedy
David Garner
I'm not sure there are particularly good years, but my 1993 Standard is a great example. The 1990 should be in that ballpark. Pickups were not ideal, but they work well for what they are. The 2000 honestly should be in that ballpark too.
The Traditionals recently are great guitars, as are (obviously) the Historics.
Axeman16
like its been said in this post it depends what specs you want.
early 2000's produced some nice guitars
moreles
If you want to inventory differences that exist in different periods, that's one thing and makes sense, but the generic "better" is meaningless. Specific example: some people love the feel and tone of maple necked LPs and may want to know in what periods those are found. Others may prefer mahogany, and want to know when those are common. Neither is better. It's preference. And as for claiming that 58 or 59 spec is best, the market may treat those as most expensive, but most of the guitars being recorded today do not sound like either, and most of the guitars being used today do not play like either. The 58/59 spec is only "best"if you have for some reason decided that's what you want. It's probably arguable that in terms of pro use and records bought, the Norlin years may well be the high point for LPs in use.
Paf1967
It would be nice to have a definition of good and bad. Saying that something kicks something else's a$s says nothing.
So what is it? Sustain? Resonance? Weight? Playability? Workmanship? Construction? Aesthetics? Resale value? All of these?
I think that the answer is easy - the closer an LP is to the best original 59 spec LPs the better it is. This includes resale value. This makes it easy to quantify an LP's worth from any era because there were certain undesirable changes in each later era.
I would term everything else as preferences. For instance, if somebody likes chambered LPs from 2008 that's fine. A chambered LP may sound 2x better than a solid one, but it won't sound and feel like an original LP. So, it might be more of a guitar, but not as much an LP as the solid one. So, it's value in terms of being an LP will be significantly lower.
The marketplace will tell you the same thing.
So, one can find a good guitar from every era, but you can not say the same thing about a Les Paul.
You no what? You are 100% incorrect. You can line 10 Les Pauls up in a row, solids, chambered, customs. There will be one that will stand out from the crowd every time. And I mean every single time it’s like this. I have a 2000 classic and I put some burst bucker‘s in it and it’s good. It’s a boat anchor but it rocks. Then I picked up a weight relieved Les Paul and you know what? In the studio and live? Hands-down beats every guitar I own. So I disagree with your analysis.
Mockbel
Sounds like a “too late” reply.. this thread is more than one year old :)
mudface
Boo Bee
I like reading old threads that @bulletproof had post in.... I miss him.
Never to late..... not for MLP;)
coreydm676
The Cosmos
My 2000 Classic is a wonderful guitar. In that year this was considered a plain top.
smallstar67
My 89 custom plays and sounds better than my old 72 custom. I just got a 2020 gold top that is very impressive. Made by a CDC of the old 57’s. It’s hard to put down, the 89 however is an album maker.
monstruo_loco
‘68 and ‘74 Les Paul Customs are supposed to be good years, I can vouch for the black ‘74 I owned, definitely was not a slim ‘60s neck in a very good way. ‘64 Melody Maker was a good one for me too. ‘76 Explorer had a nice ‘50s style neck, currently have an ‘09 R0 (someone earlier said not a good year?) ‘07 R8 I just bought & love so far, ‘08 Traditional burst, & ‘17 SG Standard T.
Like someone said earlier, if you asked me these were the best years & I'm sticking to it!
simon connor
The luthier I have had work on all my guitars (three of them Gibsons) said he could make any Gibson into one of the really great ones. He was a very impressive luthier and was renowned around Seattle; his name was Mike Lull. He said it was a matter of fixing Gibson’s screw ups, and those were usually that they did not put enough glue in the neck joint, they did not put enough glue under the frets, and they failed to operate their plek machine properly. I pressed him on it, and he said the same was true for Martin acoustics: he could make any D28 sound fantastic just by fixing Martin’s QC lapses. I don’t know if all that was true - he certainly made all my guitars play and sound great - but he clearly felt pretty strongly about it, ie, that Gibsons and Martins were great instruments, but that they sometimes needed some skilled “adjustments” to get them to their full potential.
jbash
People get a mediocre Les Paul, and years later "yeah..that was a bad year"
People get a righteous one and "yeah, XXXX was fantastic!"
Certainly one may prefer a certain model years specs over another. And at certain times I believe Gibson has had better QC (In the Y2Ks for example -before they started plekking guitars, the fretwork was not consistent at all) But I've played and owned killer and horrible Gibson guitars from every decade back to the 1970s.
But I have learned to try to judge Les Pauls as I would people- On their individual merits.
lpfan1980
I would assume their would be good LPS and bad LPs every year Ive even heard from some that even a couple of the coveted Bursts were mediocre so there ya go :D.
MSB
i really can't wrap my head around the fact that people don't see that there are good and bad examples every year, for every product....
if someone really believes that all XXXX years are great and all XXXX years are garbage, here's your sign
lpfan1980
1951 TERRIBLE YEAR FOR LES PAULS they were so hideous Gibson made them all disappear.
