Tweaker
- Joined
- Jan 18, 2012
- Messages
- 3,028
- Reaction score
- 2,355
Hi guys,
I am finishing up an acoustic ukulele that I used the super old figured redwood for. I've taped off where I'm going to glue the bridge down, but since this isn't a solid body instrument, I'm not sure how I'm going to clamp the bridge without cracking the top or back. I guess ultimately, the question is how much clamping pressure do you need with Titebond (I, II, or III)? Can I get a solid glue joint just by placing say, a dictionary on top of the bridge while it dries?
Here are a few pics with just a few coats of shellac on:
Second, I've wiped on about 17-18 coats of dewaxed shellac over the last couple of days. I wiped it on because it's been extremely humid here lately...sort of a modified French Polish. I wet the pad enough to apply a decent coat before it started to stick to the previous coat. I didn't do any kind of oil on the pad to prevent stickage, so my final coat isn't perfectly smooth. (Didn't want to mess around with the oil without testing the process elsewhere) So today I plan on doing some level sanding and polishing the shellac. I know I can't use a buffing wheel because the heat will destroy the finish. My question is, can you level sand with a random orbital sander and a 600 or 800 grit pad? Will that be a high enough grit that I won't cut through the finish too fast? Perhaps its safe to just use a piece of 320 and do it by hand?
I read somewhere that you can also take a small amount of shellac and slightly more denature alcohol and rub the final coat smooth...does anyone have any experience with this?
Thanks!
Thanks!
