Fletch
- Joined
- Jan 16, 2009
- Messages
- 3,029
- Reaction score
- 1,586
I mean the neck through, layered ones... I have a stash of mahogany from some furniture that I've had for a few years. It is awesome old wood that mills up really nicely but not quite the dimensions for a typical guitar body, the thickest it gets is about 1.250". So I'm thinking Reverse Firebird... couple questions because I can't figure this out through the search function. All the plans I see around the internet mention nothing about construction...
1) what are the layers of the center of a neck-through firebird? It looks like five pieces of mahogany sandwiched together, but there seems to be very thin layers of wood that look sort of like pinstripes between the layers on the pictures I see around the internet... is that just a glue line or something?
2) how thick are the "wings" on a Firebird?
3) how are the "wings" glued to the center section? is it just a flat glue joint? I seem to remember something about it being milled as a slight "V"shaped...
4) what is the headstock angle? 17? or 14? taking vintage 1960's dimensions... neck angle would be good to know as well
5) is there a headstock veneer glued on or is it just the stepped shape milled out on these?
If anybody has some good pictures of a stripped vintage firebird , particularly the bottom by the strap pin showing the layers and construction they could share it would be very helpful.
thanks!
fletch
thanks!
fletch
