gibson posts pic of 2018 guitar with cracked headstock
PierM
At least means they do read forums and are reading the comments in their official pages!
We've seen that since day 1 of those tease shots :)
Phusion974
Highly doubt that's a cracked headstock.
Looks more like polishing or rubbing compound to me.
9 times out of 10, a crack is following the grain of the wood (vertically), not across.
You think with all the guitars Gibson has at their disposal, they would use a damaged one for a photo?
sk8rat
wow, really didn't expect this from Gibson.
where have you been the last 4 years? their quality control is absolutely garbage. I received two brand new les pauls with chipped finishes, dings, broken pots, unfinished wiring and horrible fretboards.
this is a pretty deep gouge.
also a pretty big chip on the other side
the bottom of the headstock veneer isnt straight at all
horns_up
Is that fretboard peeling?
sk8rat
Did they do a good job on the repair?
I would say they did just enough to say they didnt do a sh*tty job. they just sanded it down. there are still some spots where I can see it along the edges on the upper frets but not enough to bother me. If I want to get rid of it I can just hit it with a high grit sand paper. they got the worst of it.
fleahead
That is most certainly a cracked headstock. I've a couple, I've repaired scores over the years.
horns_up
I
Is it a 2017?, seems like there are alot of them out there with fretboard issues like that. I can't believe the amount of garbage coming from the factory recently. Ridiculous.
sk8rat
I
it was built in 2016 but technically its a 2015.
