Gibson P-90H, Anyone split them ???
wild turkey
I have a very nice Billie Joe Armstrong Jr that I'm not playing because of the noisy P-90h. I've shielded the guitar which should kill most of the hum but to no avail.
So my question is has anyone dissected the pickup or split the dummy coil & what was the outcome?
Was it back to a normal P-90 tone ?
Are these a standard P-90 with the dummy added ?
Thanks in advance
wild turkey
OK since I got no responses I guessed no one had done this
So I went ahead & done it
Its an easy fix that involves soldering 2 wires
& you get a real P90 back that is quieter than the original & doesn't have the mid range hump
Original reading was 13.5 ohms
Stripped back the tape on the dummy coil ( bottom coil )
To reveal 2 sets of wires joined,
One set of white , 1 from each coil
And one black coming from the top coil going to the core of the braided wire
I desoldered both connections & soldered the 2 wires from the main (top) coil to the braided wire
white wire to the core wire & black to the braiding its self
The dummy coils black wire was originally soldered to the braiding so I left it
I taped up the dummy white wire so its isolated
Stuck everything back together & checked it with the multimeter again
8.1 ohms is about average for a p90
Plugged it in & it started growling & barking at me with no midrange & lot less hum
Sounds as a p-90 should
Hope this is of help to a few of you !
suedehead
Fantastic post. Glad it worked out for you. I was looking at getting a BJA but I'd have wanted a P-90 rather than the P90H. This might just tempt me....
wild turkey
Thanks
My guess is its a regular P-90 with the dummy coil fitted ,you could remove the dummy completely by undoing the screw polepieces & no one would be the wiser
Taiki
Hello! I bought Les Paul Jr BJA 3 month ago.
I don't like H-90 sounds and trying to separate dummy coil now.
I also have Les Paul special, I love P-90 sound!
The flicker's photo on this page is unavailable and I can't know process details.
Could you upload photo again?
Sorry if I have made any errors in my English writing.
yamariv
Just found this thread..OP so you're saying that your original P90 with the dummy coil had more hum than removing it to make it a regular P90? Something must have been wrong with the original P90h.. Glad you're happy with it now!
Taiki
Thank you for uploading images!
I referred to these and could split the dummy coil.
I don’t know the sound is the same as original P-90 but my guitar sound was improved.
Thanks!!
