Gibson Flying V - Wolf Hoffmann from Accept - looking for details
darkvoice
hi all,
Big fan of Wolf Hoffmann here, to me he's one of the best guitar players. In case you don't know Wolf is a founding member of German heavy metal band Accept (in 1976):
He's been playing various Flying V guitars through the years, he started with Gibson V, then used Hamer and currently plays Framus.
I am trying to understand modifications he's done to his white Gibson Flying V which he played in the 1980s. It appears that his white V is from 1970s. which originally was equipped with some sort of Nashville bridge and tailpiece stop bar.
However, in most of the photos from the era you can see this guitar with some sort of a nickel plated tremolo / floyd machine instead of a stock stop bar.
My question are:
1) Was tremolo stock on the 1970s Gibson Vs or did he modify his instrument?
2) If it was a modification - how exactly was the tremolo machine installed?
I would appreciate if we can gather detailed information on this, with better photos and links to articles/sites.
Thank you!
stp
there no trem there
. it has fine tuners and some sort of bridge.
efstop
His Framus sig edition has a Floyd with an FU Tone Block, so he might have started using Floyds with the Gibson.
darkvoice
there no trem there
You could be correct, but it seems there is a some sort of a trem.
Look at he below photo - you can see two posts for removed stop bar, then above two posts there's some sort of trem-like machine. It it's not tremolo - what is that?
It also looks like the bridge was removed and this micro-adjustment/trem piece was installed instead.
How is it held in place?
darkvoice
He certainly installed Floyd on his other guitars.
I had a chance to handle his Strat from 1980-90s and he had a Floyd Rose installed on it. There was no cavity created for Floyd, it was just put there on top of the guitar and it worked only one way - up.
Here are some photos of his modified Strat.
veeman
I don't think he ever played a Hamer, but did have a Jackson custom made. I don't recall a Hamer anyway.
LSAR
The V's bridge appears to be a Schaller 456 wraparound/combination bridge/tailpiece. Iommi has used them as well, I believe they were on the market still up until a couple of years back.
darkvoice
Thanks a lot! It certainly looks close enough.
What would be the benefits of replacing Gibson's bridge and tail with Schaller 456?
LSAR
The only thing I could think is that he wanted the fine tuners he was perhaps used to having on a Floyd. It isn't a mod I'd personally think makes sense. It doesn't look like he added a locking nut, so there wouldn't be any particular benefit to tuning stability.
I'm not sure but I think these have different post spacing from a standard tune-o-matic so I imagine the original post holes had to be filled and re-drilled for the bridge...personally I'd have opted for a Gibson TP-6 that would drop in without modification.
darkvoice
Many thanks!
kkmacgoody
The guy pulled a Peter Frampton....big head of blonde hair then gone.
Many of us pulled a Frampton - age tends to take hair away and leave you with fewer options - dissliked Frampton as a kid (too pop-y); I prefer the relic'ed version - more thoughtful and he still has his chops
