Full_Stack
- Joined
- Apr 16, 2010
- Messages
- 814
- Reaction score
- 840
Alright - this will be my first headstock repair/replacement..
The victim - a 1966 Gibson Dove, saved from the trash!
The headstock was poorly repaired twice. It's a mess of epoxy, laminated veneers, and steel fasteners
She's way beyond splines (I would assume) ..and since it is a laminated neck I would like to opt for a new headstock grafted in. My "plan" is to remove the fretboard and binding (the binding is sanded super thin and it needs a refret), then cut the neck at the same angle as the headstock (hope my description makes sense..). This is my poor-man's computer generated sketch
I would then laminate a new headstock section onto the neck cut and blend it into the contour of the neck on the back side.
Would this be a strong joint? Is this the best way to tackle this break?
