Getting ready to do some work on my #1
metalmike222
So, I've been wanting to do some work on my #1 guitar for a few years now. It's a 79 Les Paul Standard and I've absolutely loved it since the day I bought it in !994.
Here it is in all it's glory. It's a fairly typical Norlin era natural finish Standard, but for me it's pure magic. The DiMarzio X2N in the bridge was actually in it when I bought the guitar, and because of that, the X2N is now pretty much my favorite aftermarket pickup. The first thing I did to it after buying it was replace the Kluson tuners with Grover tuners (unfortunately lost the Klusons years ago...), hoping to relieve some of the tuning issues. It wouldn't be until MANY years later that I learned about pinching string paths through the nut and things of that nature. I also removed the toggle switch poker chip and the pick guard, because it's just SEXY! It's also had a refret in the last 5 years or so. Now it's time to move on to some other items.
I plan on replacing most of the electronics, from the toggle switch, to the pickups, to the pots. I just got my new pickups delivered on Friday.
Surprise, surprise! It's a new DiMarzio X2N and a matching D Activator-X for the neck position. I'm replacing the bridge pickup because I've been playing it for so long, the plastic on the high E edge of the bobbins is wearing away fairly significantly. My OCD also wants the pickups to finally match, which is what's prompting adding the D Activator-X this time.
I've also picked up a new bridge to replace the 41 year old original that has seen better days.
Among the not yet purchased parts are the toggle switch and pots. I'm also strongly considering a String Butler to further address the previously mentioned tuning issues. I've seen some pretty promising video reviews of them so I'm really curious.
The final thing that I'm still on the fence about... Being a 79, there is no ground wire from the bridge to the electronics cavity. From what I have read, the original pickup cover was part of the grounding system of the guitar, and since mine has never had the original pickup since I've owned it, it's always been pretty noisy on the bridge pickup. Especially since I play loud, distorted rawk! Now since I'm going to be replacing the neck pickup as well, I worry that the noisiness might get worse, or at least it will be noisy on both pickups, not just the bridge. So... I'm considering pulling the stud for the tailpiece and drilling into the electronics cavity to run a ground wire. REALLY nervous about it, so I'm also considering just get a noise gate for it, but if I can manage it without completely wrecking my baby, I would rather just fix the issue as opposed to cover the excess noise.
Anyway, that's where I'm at with it. Sorry for the really long post. I'll order the rest of the parts in the next few weeks and work on all of it at once. Let me know if anyone thinks I'm crazy! :)
VictorB
Formerly LZF
The X2Ns are Fender spaced?
Also, with a properly cut and lubed nut, there’s no need for a string butler.
Nice upgrades though!
Side Burns
Good MF choice there. Have you ever used a Bill Lawrence pickup? DiMarzio was Bill’s apprentice back in the day.
Heres the X2N on my ‘13 Standard that matches the Gibson Historic rings pretty well
heres the L500XL that inspired me to try the DiMarzio.
Hope you don’t mind the derail pics.
metalmike222
Yeah, F spaced are the only option for those pickups. DiMarzio lists them as "universal spacing" on their website. I was also looking at Big Bends Nutsauce, so I might try that before I try the string butler.
Those are some awfully pretty fiddles! I actually HAVE a Bill Lawrence pickup in a cheap parts guitar that I got from a pawn shop years ago for $150. That was the guitar I bought to try new things like refinishing. The refinishing job I attempted was pretty terrible, but the pickup itself was probably worth the money I spent on the guitar. Maybe I'll pull it out one of these days and slap it into a real guitar. I have enough of them laying around to try. :D
Side Burns
Thx,
if you have a guitar to install pickups on, 1 of the BEST setup is the APH-2 in the neck and Dimebucker in the bridge. The Dimebucker got me to try the OG L500XL, & that got me to try the X2N
ok ill stop blasting pics after this... I promise:fingersx:
metalmike222
I have an LPJ that I picked up for about $400 at the beginning of the year that still has stock pickups. Maybe I'll try that Bill Lawrence in that one. Pretty sure the one I have is an L500, but honestly I haven't even looked at it in years. That LPJ is really bright sounding with the stock pickups and I was already wanting to swap out the pickups, so maybe the BL will be a better fit for it.
metalmike222
@Side Burns, here's a couple of pics of my Bill Lawrence.
It's definitely seen better days, and I'm not really sure what model it is. I thought I remembered seeing L500 stamped on it somewhere, but I don't see anything on it now. I haven't even touched the guitar it's in for probably close to 10 years, so it may just be time to strip the guitar and keep it as a donor/experiment guitar. I don't even know what kind of guitar it is, and I can't explain why I bought it other than to say I was looking for something to experiment on. The finish was the pink/purple You can see under the bridge so I figured I couldn't make it any more ugly than it already was.
Roxy13
Why not take it to a luthier for the ground wire and the nut? I think you'll be happy if those get addressed.
I've only drilled one so far and it was nerve wracking. Although since I want to build I'm going to have to continue doing it :)
metalmike222
I want to start getting into building as well. Thinking about starting with the StewMac mini strat kit for a fun project to build with my son.
I have thought about taking it to a luthier for the ground wire though,and I might end up doing that. The nut was addressed when it was refretted, and it helped a bit, but the tuning has just never really been THAT great.
metalmike222
I actually reached out to the guy I bought it from back in 94. He's been working as a professional guitar tech for national acts for probably close to 20 years now. He's going to drill and run the ground wire for me. Might have him go ahead and do all the work. I've known him for a long time and really trust him.
Mark_the_Knife
I actually reached out to the guy I bought it from back in 94. He's be working as a professional guitar tech for national acts for probably close to 20 years now. He's going to drill and run the ground wire for me. Might have him go ahead and do all the work.
Good choice. Never practice complicated repairs/mods on your number one. Drilling a hole with a rt handed chuck in a tight position is no ones idea of fun. I have some broken guitars from my step-daughter that I use as mules for repair jobs. There are also wrecks that you can buy from a pawn shop to practice BCR Greg-style repairs. After which, you may want to swear off anything that is the bread and butter business of pro luthiers.Nothing beats their years of experience.
metalmike222
Yeah, I have a no-name guitar that I got from a pawn shop years ago for exactly that purpose. I've tried a few things on it, but I just don't have the experience to do anything drastic to my baby. I decided to be safe and deferred to more experienced hands.
metalmike222
Just got it back from my buddy. Super happy with the results. No more high gain hum, all new electronics and pickups, shiny and clean, and still plays and sounds amazing. When I picked it up, e said, "Man, I REALLY shouldn't have sold this guitar."
I replied with, "I agree, but I'm awfully glad you did!"
