George Lynch wiring question
45WinMag
How would you go about adding a single master tone to this wiring setup? Would it be a good idea to wire a 500K resistor between the single coil ground and pot to make the single coil 250K?
mux164
in my limited experience i have had single coils on 500k pots, didnt make too much difference to my ears
Baylin
Nah don't bother adding the resister unless you really want to. I'd just fit a 500k linear pot opposite the vol pot so the lugs are mirrored. Then wire a cap (my fav is 0.022uF) between the centre lug of the tone pot and the left lug of the vol pot. Then solder the left lug of the tone pot to its base.
Job done!
45WinMag
Thanks! I think I get it now. I was over-complicating the DPDT switch in my mind. Baylin's post helped me to mentally separate the switch portion from the pot portion of the push/pull pot. Makes sense now, I was way overthinking it.
Thanks to both of you for advice on the resistor. I'll just leave it as a 500K for the single coil.
Baylin
Oops - Don't forget to link the tone pot base to the vol pot base so that it's grounded!
