Dilver
- Joined
- Apr 25, 2011
- Messages
- 2,460
- Reaction score
- 4,623
Hand built, point-to-point wired, 5 watt Class A Tube amp. Almost new condition, kept in my temperature and humidity controlled music room. Specs from Swart’s website:
Swart Amplifiers STR Tweed 5 Watts Class A 12" Speaker Combo Amplifier Features:
5W CLASS A ~ JUST INSANELY BIG TONE BREAKUP!
Single-Ended Output - Zero Negative Feedback
100% Tube Circuit - GZ34 or 5Y3 Valve Rectifier
Big Swart Tube Reverb - Foot Switchable
Hot and Clean mode Switch
Powered by choice of 6V6 or 6L6 (shod w/6V6)!
JJ 12AX7(2) - JJ 12DW7 - EH 6V6GT - JJ GZ34 Rectifier
Point to Point Hand Wired Circuit
Cathode Biased (no need to bias)
Carbon Comp Resistors ~ Mallory Caps
Cloth Hook-Up Wire
Hi/Lo Input for High & Low powered Pickups
Heaters referenced to ground
Standby Switch for tube warm-up, extending tube life
All Swart Amplifiers employ Star Grounding
4/8 ohm 1/4" Out - Drive other Speaker/Cabinet
Switchcraft 1/4 inch inputs and output
CTS Potentiometers
Custom High Quality USA Built Swart Spec Iron
Speaker: 12" Mojotone BV-30H ~ 8 ohm
Finger-Jointed, solid Pine Cab w/ Lacquer Tweed Cover
Circuit Fuse Protected
Pre-2015: 17" W x 9 3/4" D X 16 3/4" H (w/feet)
This demo video by Sam Vilo is the best demonstration of what this amp sounds like with a Les Paul:
Includes Swart Night Light Attenuator installed. Description from Swart’s website:
Smaller is better sometimes. In this case, the Night Light Jr attenuator packs a punch in a tiny package. We wanted something to hide in the port of the ST-6V6se, Atomic Jr, STR-Tweed, and STR-Tremolo. Something more simple, bare bones, something designed for the low watt sect. The first 25 Night Light Jr are sitting here waiting to be mounted within our low watt amps or tossed within any 4-8ohm amp that is 15w or less. Sounds sublime and even has some of the Night Light Blue Magic while at work. Less features than our main Night Light and really designed for mounting vs stand alone. But we're really digging this little beast and loving the way it brings that Swart Low Watt breakup at more manageable levels for those in need inside the smaller combos. Will be able to be custom ordered within our amps soon, too!
$1,300 or straight up trade for a 2019-2021 Les Paul Junior in Ebony finish. Also interested in a Marshall 1974x (with a little cash from my end).
Local deal preferred (Northern New Jersey) but will ship at buyers expense. PM me and I can find out what actual shipping costs will be, depending on your location.
Cloth Hook-Up Wire
CTS Potentiometers
