FS Swart Space Tone Reverb Tweed in Dark Tweed
egrassel
Looking to sell my Swart Space Tone Reverb Tweed in Dark Tweed - This sound is unique, yet familiar. Tweed sound in its blood - with a reverb that is out of its world. 5 watts, through a 12 inch speaker sounds huge. I have the opportunity to pick up a vintage tweed, so I gotta move this.
1000 shipped pp/gift -
The point to point, hand-wired STR-Tweed has three driver/preamp tubes comprised of two 12AX7s and one 12DW7 with a parallel Reverb stage utilizing the 12DW7 & 12AX7, providing the circuit with virtually zero insertion loss. And like all Swart amplifiers, the STR-Tweed is tube rectified by the JJ 5AR4/GZ34 for the best AC filtering bringing great compression and tone, avoiding the typical solid state harshness that seems to ride along with solid state rectification. Try a vintage 5Y3 for a bit more SAG and less voltage on the power tubes.
STR-Tweed Specifications
  • 5W CLASS A ~ JUST INSANELY BIG TONE BREAKUP!
  • Single-Ended Output - Zero Negative Feedback
  • 100% Tube Circuit - GZ34 or 5Y3 Valve Rectifier
  • Big Swart Tube Reverb - Foot Switchable
  • Hot and Clean mode Switch
  • Powered by choice of 6V6 or 6L6 (shod w/6V6)!
  • JJ 12AX7(2) - JJ 12DW7 - EH 6V6GT - JJ GZ34 Rectifier
  • Point to Point Hand Wired Circuit
  • Cathode Biased (no need to bias)
  • Carbon Comp Resistors ~ Mallory Caps
  • Cloth Hook-Up Wire
  • Hi/Lo Input for High & Low powered Pickups
  • Heaters referenced to ground
  • Standby Switch for tube warm-up, extending tube life
  • All Swart Amplifiers employ Star Grounding
  • 4/8 ohm 1/4" Out - Drive other Speaker/Cabinet
  • Switchcraft 1/4 inch inputs and output
  • CTS Potentiometers
  • Custom High Quality USA Built Swart Spec Iron
  • Speaker: 12" Mojotone BV-30H ~ 8 ohm
  • Finger-Jointed, solid Pine Cab w/ Lacquer Tweed Cover
  • Vintage Jewel Lamp ~ Circuit Fuse Protected
  • 17" W x 10 3/4" D X 16 3/4" H (w/feet) ~ 29.5
View media item 108089View media item 108090View media item 108091
