FS - 20W V2 Caldera amp head
V2
Single-channel higher-gain amp with vintage and modern modes. It maintains clarity and articulation even at higher gain settings.
Tube compliment:
- 2 JJ 6V6S, fixed bias with individual bias monitoring and adjustment for each power tube.
- 3 hand-selected 12AX7s for the preamp and phase inverter.
Front-panel controls:
- Gain, Volume (Master), Treble, Mid, Bass, and Presence.
- Mode switches between vintage and modern settings
- Bright switch adds high end with Gain is rolled back.
- Punch adds gain while keeping things tight
- "Cali Clipper" switch engages a diode clipping circuit to add distortion and saturation. Similar to Friedman SAT switch.
Rear-panel controls and features:
- 4, 8, and 16-ohm speaker outputs
- Fat switch to tailer the low-end when in modern mode.
- space for a buffered effects loop.
Additional info:
- top-quality components including custom Heyboer power and output transformers, Hammond choke, F&T filter capacitors, Mallory caps, Alpha potentiometers, etc.
- Layout and grounding scheme optimized for low noise, clarity, and articulation
- Low-noise DC heaters for all 12AX7 tubes.
US$1200 + actual shipping costs.
Effects Loop may be added for additional cost ($150).
367960
367961
367962
V2
$1100 + shipping.
368923
368924
V2
bump with lower price $1100 plus shipping.
Want to pound a pink taco? This is the PT Pounder (PTP20)!
