pshupe
- Joined
- Jan 19, 2012
- Messages
- 5,880
- Reaction score
- 6,496
So I finally got these things rolling a little while ago. There are 2 fullsized templates, one with the modern scale of 24.562" and another using the vintage scale "rule of 18". The smaller version has the 4 different sized inlays. They all have diamond notches cut in the side of the templates which mark the centre of each inlay, so you can line them up with any fret scale length.
The basic premise is to use a dremel tool with a stand and a straight bit cutting tool. I used an 1/8" cutter bit and that works about the best. The jig holds the template at the right height so that you can run the edge of the bit, above the cutter, around the edge of the template to the depth you want to recess your inlays. You have very little clean up to do in the corners of the inlays. It speeds up the inlay process and is very precise to both have a tight inlay pocket and exactly centred between the frets.
Cad drawings of templates - V - Vintage rule of 18 scale with the trap inlays centered on that scale and M - Modern 24.563" scale length with trap inlays centered on that scale. Small template with the 4 sized inlay outlines to be aligned with the center lines of any of the inlay pockets.
General dimensions for building the jig
The outlines of these templates are offset by 1/64", which means if you want them slightly oversized you would use a 1/8" bit and the inlays will slide right in. If you want to cut exactly the same size as the inlay you can use a 3/32" cutter with a 1/8" shaft.
These are laser cut from 1/8" stainless steel material. 3d view of template sitting on top of jig with fret board in between.
Here is a pic pif my father cleaning up the corners after routing the pockets.
here is the fit -
These are available at Bartlett Woodworking
Check out Tom's other cool items on his site as well.
Let me know if you have any questions or thoughts on how to improve. I will be working up a headstock template, and possibly a custom inlay template, in the near future as well.
Cheers Peter.
here is the fit -
Cheers Peter.
