surge98
- Joined
- May 14, 2013
- Messages
- 159
- Reaction score
- 52
Maybe I'm just being too picky with my setup preferences, but I have a Musikraft neck with a 12-16" compound radius, designed for an Original Floyd Rose nut with a 10" radius. I had assumed any issues with using a 10" radius nut on a neck that is 12" at the first fret would be minimal, since there are a number of guitars that do this. Using my StewMac nut slotting gauge, I'm measuring a height of .022 on the G string and .02 on the D. While these aren't crazy high measurements, I would never leave the slots that high on a standard nut. I would typically aim for somewhere around .013-.014. My other Floyd necks came from Warmoth with a 10-16" compound radius, and can be dialed in perfectly at the nut.
So my question is, would I be crazy to use a small V-shaped diamond file on a hardened steel nut to knock down those slots a tiny bit? The nut shelf was actually a little high when I received the neck, I carefully took it down a bit until the other four strings were set at the proper height. So I don't want to lower the shelf any further, and I've already shimmed the saddles to account for the compound radius. Has anyone ever run into this problem with a locking nut? Thanks.
