Final upgrades done...
KelvinS1965
I've had my Epiphone Les Paul since 1995, according to Paruwi on another thread it is a 1990 model, so coming up for 30 years old. I had to replace the bridge as it had sagged, had a new nut fitted and set up. Later I replaced all the electronics due to crackles, then put a set of Bareknuckle Mule pickups in it. I rushed the pickup job, so I always intended to go back and tidy this up. Finally got round to this a few weeks as I wanted to replace the wiring with metal shielded cable as I had a gig coming up and wanted it properly sorted.
This is the control area before:
Remade the output jack wiring and heat shrink sleeved to prevent shorting:
The selector switch had been changed to a Switchcraft one a while back, but using the original wiring:
The control panel afterwards. CTS Pots and vintage wiring method:
I adjusted the heights of the Bareknuckles and really got it sounding how I want it to. I recently bought the new Marshall 20 watt 'Plexi' head (SV20H) and the LP sounds great through it.
This is just before I went on stage for the gig...we played Money for Nothing by Dire Straits, hence the outfit (even if not period correct as it turned out):
straybeat
I'll bet if you re-magnetized the Epi pickups, you'd have a brand new set of killer ones there too?
KelvinS1965
They were very microphonic and dull sounding, so I'm not sure they would be worth the effort. I put them in the Bareknuckles box just incase I need them in the future, but can't imagine why when the BKs sound so good.
