Fender '57 Custom Champ Review
Dilver
Just got this amp used: https://shop.fender.com/en-US/guitar-amplifiers/vintage-pro-tube/57-custom-champ/8160500100.html
I've been using my old 1960 Supro 1616T quite a bit lately and fell in love again with it's simplicity, low wattage and small cab/speaker. Combined with a good Les Paul, it's a great sound. This set me down the path of looking at older, smaller, point-to-point amps like old Gibson GA-8s and GA-5s, when this '57 Custom Champ came up and I thought I'd take a chance.
For context, I have 3 other amps:
  • '65 DRRI w/Fritz mod and C-Rex
  • Swart STR Tweed
  • '60 Supro 1616T
... and so far, have tested this amp with a 2017 Historic Les Paul Standard (R8) equipped with Peter Florance PAF's, a Fender/Warmoth Tele build, Fender Am Std. Strat, and Gibson CS-336.
Construction/Build quality: It's solid. The cabinet is sturdy, finger-jointed solid pine, all wiring is neat and tidy, and the lightly lacquered tweed covering is flawless. For what they're asking for these things, at least nothing feels "cheap". There's a cage around the rectifier and power tube, and even though its not "vintage accurate", it's there for international safety compliance reasons, so no complaints. I'm toying with the idea of just removing it, for easier access to the tubes. But I'll probably leave it so I don't lose the part.
Looks: Classic Fender Tweed. It's small and it looks small; almost like you can't take it seriously because it's so small (don't be fooled). But if you can get past the size, it's a nice looking amp.
Tone: First off, it's deceivingly loud considering it's diminutive size, small speaker (8") and 5 watts. It doesn't sound boxy, but of course, it doesn't have the thump and doesn't move the air of a big cabinet with larger speakers. But the sound is large and full; this amp provides a wide range of frequencies and sounds much bigger than it's size.
Turning the volume past 4, you start to hear some grit when you dig in to the strings on a Les Paul. with this guitar, the "sweet spot" seems to be in the 5.5 to 8 range on the volume knob. With the Tele and Strat, a little higher. This is where you get all the dynamic response - touch sensitivity, with single notes jumping out and nice bloom on bends. At this setting, the interplay between amp and the guitar's volume control offers lots of options and I found myself easily dialing in nice classic rock overdrive and bluesy tones and "cleanish" tones when rolling back the volume on my Les Paul. Plug in the Strat and you've got the Clapton "Layla and other Assorted Love Songs" tone instantly. As you get closer to the 8-9 range the tone becomes more compressed and chords take on a great distortion that's still what I'd describe as "full frequency". Notes bloom into controllable feedback with ease. From 10-12, the volume increase is less noticeable as the drive becomes hairier. I got a satisfying "sag" when bending lower strings hard and cool Neil Young tones.
Tube Rolling: I've developed quite the collection of old and NOS tubes, so I first swapped out the stock Ruby Tubes 5Y3 for a NOS Tung-Sol 5Y3. A bit more sag, but not really a big improvement, so I tried a 1960 RCA 5Y3. While I understand that most folks say that the rectifier tube shouldn't impact tone, but more feel, I think the two go hand in hand, and the switch in rectifier tubes was noticeable. Next up, changing the Groove Tubes 6V6GT that the previous owner had installed, to a late 1940's RCA 6V6GT. Combined with the rectifier tube swap, it was like the amp suddenly "woke up". Much more lively and responsive. Lastly, I didn't have another 12ay7 preamp tube, so I tube rolled an RCA black plate 12ax7, Mullard 12ax7, Sylvania 12ax7, RCA 5751, GE12at7, and Sylvania 12at7. Fun.
I can see why some people like to use a 12ax7 in a 5F1 - you can get push the amp into a more saturated overdriven tone at a much lower volume. But its almost too much and too early. I prefer having a bit more volume at lower settings. I had read about someone recommending using a 12at7 with a Champ when using a guitar with full-sized humbuckers. The GE 12at7 boosted the volume and clean head room significantly. With the guitar's volume control dialed back, I got a great tone that was lively and clean-ish. After switching back and forth between the stock Fender 12ay7 and the GE 12at7, I thought the 12ay7 sounded sweeter in higher frequencies. But that 12at7 clean volume boost may be something I revisit later. Both sound great; just a matter of preference. I'm looking forward to trying some older 12ay7s in the coming weeks.
Conclusion: Overall, the '57 Custom Champ rocks. It's a keeper and really exceeded my expectations. It *might* be loud enough to gig with unmic'ed if you've got a drummer with a light touch and a quiet audience. But mic'ed and put through the PA, you'd be able to get great overdriven amp tones without blowing your ears out - the whole point of smaller, low wattage amps. The simplicity of the 5F1 circuit, with it's one rectifier, one power and one preamp tube, allows you to try different tubes without needing to adjust bias and get a variety of gain levels. But the beauty of this amp is the interplay between amp and guitar and the range of tones achievable by simply adjusting the guitar's volume control.
Since I picked this up used, I paid WAY less than the $999 street price (which is ridiculous for a 5F1). Still, I'm sure I probably could have built one for less. But I have to say - this amp is even better than I hoped it would be.
Frogfur
I have a Champ. Not a 57, but the Eric Clapton Champ. I love the amp. Miked, it is pure heaven.
What really helps with these small amps, especially with crappy room acoustics is one of these -
Really helps in certain situations.
Dilver
I was looking at the EC Champ - very nice but also expensive. Do you use the high/low output switch? I’ve seen some mods online with this switch as well as others.
Anyone change the low input into a “speaker out”?
Frogfur
It doesn't need any mods. Stupid way to devalue a good amp. Yes they are expensive, you get what you pay for. Simple.
Dilver
I get it. Any mods I’d do would be completely reversible and with a point to point wired amp, it would be easy enough to do.
Leña_Costoso
Well as my Scot friend used to say "Eeeugh, thats a rrrreal cewstom job laddy".
I wonder who bought the Schumacher transformer name?
Champs are great. One control. All you really need. Liked mine with a 12" in a Deluxe size cabinet (thanks Mojo !). Best of luck with that wee beastie.
Splattle101
Nice review! I really like the 5F1 Champ. Like LC above, I built one and put it in a larger cab with a bigger speaker. In my case the cab was for a tweed Princeton, and the speaker is a 10" instead of the stock 8" driver.
Dilver
Got two NOS RCA 12ay7s off eBay, a 50’s Gray plate and a 60’s. They both sound better than the Fender Chinese 12ay7, but I can hardly tell the difference between the two of them. So now, I’m running used and NOS RCA glass in all positions and this amp sounds great. Almost a week in and I’m still loving this thing.
Marshall & Moonshine
Small amps into (relatively) large cabs are the way to go, IMO. I built my tweed Princeton as a 2x10, with WGS 10” Veterans (20w each) and it’s a small-med stage dream.
I built the cab (conveniently on the Marshall for scale) as a diagonally-mounted 2x10, with top controls.
It’ll hurt your ears, very easily.
Pappy58
Thats looking pretty sweet man! Nice job on the cabinet. :cool: Word working is not my thing, but I have a friend who is a cabinet maker who I'm gonna hit up for my next build. I need something in a nice walnut or sumthin.. :naughty:
It was a real experience learning to do all that. The whole thing is box joints and biscuits. All glued, except access to the chassis. You could throw it off the roof. :)
My friend re-housed his Champ 600 in a 1x12 and it’s a nice small stage amp as well.
Some efficient (but low-powered) speakers can really make these tiny tweeds come alive.
Dilver
I'm actually quite surprised at how this thing sounds with it's small cabinet and 8" speaker. I'm hooked!
syrinx
I bought one of these for a christmas present to myself- and agree with the original poster-great amp. I prefer it with single coils-but it sounds good with anything- likely if I used the lower gain input with HB I would be happier. I tried a 12ax7, and vintage 7025- and decided the stock tube was much better. I did put a `57 grey glass rca 6v6 in and wow- big difference! The thing I like best about it is the way you can hit the same note a thousand different ways. The compression is so dramatic as well. I made a plexi back for mine.
Duane_the_tub
Great review, thank you. My '58 Champ gets the most playing time of anything in my modest herd, as it's my go-to "just plug in and play" home amp. I agree with the sweet spot between 5 and 6, with that gorgeous edge-of-breakup texture it imparts. I have an old Telefunken 12ax7 in mine so it gets dark and stormy pretty quickly, but I actually like that at home. I can get some serious attitude out of that little box at very tame volume levels.
Dilver
Such a funny thing, really. I've been playing for years and have had all sorts of amps. I never bothered with a Champ because it seemed so... tiny.
Leo Fender designed this amp to be a low cost student model. He'd probably cringe at the overdriven tones we all love about this amp. And yet it's become one of the most recorded amps in history and his design has stood the test of time. Just like the Tele... "got it right the first time"
Mick Weiss
Old thread but still useful for Champ Ideas! I built a Mojotone Champ a while back and found it too dark for my Humbucker guitars. Pretty good with the single coils. I was thinking of modifying the cathode resistor to V1 with a switch to choose between the stock resistor (1.5K) or a 2.2K, thinking that could be used with Humbuckers for more clean tones. Has anyone tried this?
