EVH 5150 iii - 50 watt head
karaterick
Excellent condition. I’m sure you all know this amp but here are the specs.
$750 shipped.
5150III 50W Tube Guitar Amp Head Specifications:
Electronics
  • Wattage: 50 watt
  • Effects Loop: Yes
  • Inputs: Front Panel Instrument ¼" Mono Jack (Insert)
  • Headphone Jack: 1/4" Stereo Jack
  • Line Out: Line Out Jack
  • Extension Speaker Jack: 2 Parallel Speaker Output Jacks
  • Channels: 3, Channel 1 and 2 Share EQ
  • Controls: Master Presence, Channel 1 and 2: Gain, Low, Mid, High, Volume; Channel 3: Gain, Low, Mid, High, Volume, Master Resonance Control (rear panel)
Hardware
  • Hardware: Black
  • Cabinet Material: Plywood
  • Pilot Light Jewel: Red LED Jewel
  • Handle: Black Strap
  • Front Panel: Black EVH Striped Steel
  • Cover/Grill Cloth: Black or Ivory Textured Vinyl Covering with Black EVH Striped Steel Grille
  • Input Impedance: >1M ohms
  • Output Impedance: 4, 8 or 16 ohms (Selectable)
  • Amplifier Length: 12" (30.4 cm)
  • Amplifier Width: 20" (50.8 cm)
  • Amplifier Height: 8.5" (21.6 cm)
  • Amplifier Weight: 35 lbs. (15.9 kg)
Tubes
  • Preamp Tubes: 7 JJ ECC83 (12AX7)
  • Power Tubes: 2 JJ 6L6
Miscellaneous
  • Unique Features: 4-button footswitch with 1/4" cable input with ultra fast switching, MIDI input that can be used to control channels and effects loop with virtually any MIDI device, 3 foot heavy duty speaker cable
Accessories
  • Footswitch: 4-Button Footswitch Included
